- Thread Starter
- #41
Frankly, I suspected my amp from the beginning, but only in the area of general bad downmixing to phantom stereo which was later proven when I used one of the surrounds as center and the dialogues got clear.
However, the point when I realized that surround processing (and/or Audyssey) was the actual culprit was when I tried to set the AMP to mono (but which mode it does not have, only DSP mono where the rear speakers still work). While searching for a suitable mode I have also played with "Source Direct" and "Pure Direct". In those direct modes I still have a phantom center, but this time without the echo and other processings which clearly messed up the vocals to an extent that was very audible with the JAMOs and much less to not audible at all with the ELACs - those seemed to be immune to this.
The sound from the ELACs sounded overall very pristine, but 'sterile' in the sense that it was not engaging, especially the fact that the sound appeared to precisely originate from the speakers, not from the room. I am still not sure if 'originating from the room' is a positive, or negative thing, overall, for a speaker. What is the general consensus on this? Ppl call this imaging. Can there be something as too much of an imaging?
As for the AMP itself, it looks as if the AMP tried to first add the center to the R and L channels and afterwards applied all the surround effects in general and messing up the speech while at it. Not sure if it's as simple as that, probably not, just an idea. I have nevertheless placed an order for an Onkyo 3700H to see if that does it better.
