JamesDSP / RootlessJamesDSP: Android System-Wide Equalizer Measurements (including Parametric EQ)
Do you use this app?
  • I use it and will continue to use it after reviewing the measurements
    Votes: 2 33.3%
  • I use it and will stop using it after reviewing the measurements
    Votes: 0 0.0%
  • I used to use it
    Votes: 1 16.7%
  • I'll start using it now
    Votes: 1 16.7%
  • I haven't used it and don't plan to
    Votes: 2 33.3%
reallystate
A detailed report on the equalizer measurements in this app is available here.
It includes not only frequency response measurements, but also verification of the correct operation of multichannel equalization, distortion measurements, phase measurements, and measurements of equalizer artifacts such as pre-ringing and post-ringing.
Measurements were taken of the parametric and graphic equalizers and the convolver in the following applications: JamesDSP (for root devices), RootlessJamesDSP and RootlessViPER4Android.
Article about parametric equalizer in JamesDSP is available here.
You can find out my other equalizer measurements here.
Articles on how to interpret measurements of audio electronics (DACs, amplifiers and equalizers) are published here.
Why the extra URL parameters utm_source=audiosciencereview.com and utm_medium=referral?
Hello sir , first i want to say that i admire your work , and also share my latest experience with this app.
Recently i installed vanilla jamesdsp from play store , all installed and worked great but of course no peq so i uninstalled and attempted to install two of its forks : rootlessviper and by evoeram , none of which would install on my android 13 tablet. During attempted installation i was immediately getting messages like 'cancelling' or 'app was not installed' . Only when i downloaded platform-tools for android and attempted to install from my pc i was succesfull and it works great now. What i want to say is that is very strange and i hope its not a virus !!!
I use USB Audio Player with Morphit PEQ plugin on my Android phone. It's very simple and intuitive and gives me systemwide EQ for 10 channels. That's more than enough for any of my IEMs.
Hi reallystate,
I have a question regarding RootlessJamesDSP functions, particularly its convolver.
Do you know what is the purpose of "Impluse response optimization" and "Advanced waveform editing" options?
I use the app to apply room EQ correction generated by GSonic Reference. Choosing "Normal" in Impluse Response Optimization takes out a lot of harmonics and make the sound very lifeless for lack of a better term, while "Shrink" mutes the audio. Only "Minimum Phase Transform and Shrink" works normally.
Thanks!
