I've performed some Measurements on SPL Volume2 (Model 2602) volume control
Rja4000
Liège, Belgium
Hi
I own a SPL Volume 2 and wanted to check how it measures.
So I tried.
SPL (Sound Performance Lab) is a German company, specialised in Pro audio electronics.
They are not new comers in that market (they say they're in the business for 30 years).
They offer analog preamps, channel strips, control room volume and control switches, headphone amps, and some interesting effects devices.
Personnaly, my first SPL device was the SPL Transient designer 4.
This very special (unique) analog device which, although looking simple, is doing some magic inside, allowing you to modify the transient attack of live instruments.
It can do magic indeed, as an example on drums in live events.
Back to the Volume 2:
One may find doc and manual (including serious Audio Precision measurements) for this device here.
The volume 2 is a 1/2 rack wide, and some 2U high.
It's also approximatively as deep as wide. Not a small box.
The big volume knob is smooth and pleasant to use.
It's labelled from 0% to 100%.
There is also a Mute button, which lights in RED if active.
The device doesn't look cheap, for sure, and weights some...
List price is below 400€. I bought mine new, for less.
Back panel has XLR connectors only. Target is Pro audio.
Inside the box, everything is proper and neat.
Measurements
(Measurements all performed with Virtins Multi Instrument 3.8 and RME ADI-2 Pro fs.
RME DAC > Volume2 > RME ADC.)
Red: SPL Volume 2,
Black: RME ADI-2 Pro fs in loopback (DAC > ADC) for reference.
Volume matched to get same input level on the ADC
At Max level (100%) position, when fed with +15dBu (4.36Vrms), we have a SINAD of 103dB
That's a bit lower than the RME, due to a higher distortion.
We see some H2, H3 and H4. Level is very low though (THD around 106dB below signal level).
Note that SNR (un-weighted), at above 107dB, is indistinguishable from the RME, which is very good.
This is all above the specs, which are
THD & N (@ +15dBu Input Level) ›-100dBu
S/N A-weighted -102dBu
Also note that, even at Max level, there is some attenuation (around -4.3dB).
It never reaches unity gain.
The Volume 2 always provides attenuation.
Looking at the attenuation vs volume setting, we see the following
X is the volume setting, from 0% to 100%
Y is the ADC input level, where 0dBFS is +19dBu
DAC output level is 4Vrms or +14.3 dBu
Left channel is black, Right channel is red: We see a pretty good channel coherence.
Also, the attenuation is smooth from around 90% to 20%, with 40dB more attenuation at 20%
But such a volume control is rather used at lower volume settings:
Here is a trend of THD+N and THD vs volume setting
X is the ADC input level (ie the level at the output of the Volume 2)
Left channel in Black and Right in Red.
THD (dashed), under a certain level, can't be measured correctly.
THD+N (solid), mainly follows the noise.
Except at the highest level settings, where it shows a bit more distortion, the Volume 2 measures the same than the RME, when we match the levels.
(More to come...)
Here are a few additional plots
Volume @50%
Volume @75%
Notes
With Volume @50%, the SINAD performance is slightly better than the RME with the digital volume control.
With Volume @75%, the RME digital volume control still performs better.
50% is around 28dB attenuation
Distortion vs Frequency plots are at 192kHz.
The noise in high frequencies (>20kHz) impacts the figure
DAC output range +19dBu
I was expecting all distortion plots to merge at some point.
I don't understand why their "noise-limited" level is different.
I'll double check.
(More to come...)
Update:
SMPTE IMD is measured against the 7kHz tone level, which is 12dB lower.
That's why we see this noise level shift up.
That's also why nobody shows THD @1kHz and IMD on the same graph.
Maybe I should lower its level by 12dB, to make it comparable.
For CCIF IMD, where both signals are at same level, I don't know why the noise level is lower.
Still investigating...
Plots
Red: SPL Volume 2
Black: RME ADI-2 Pro fs, with level set for similar ADC level
THD + SINAD @50%
IMD SMPTE (60Hz +7kHz 4:1) @50%
IMD CCIF (19kHz+20kHz) @50%
Harmonic distortion levels @ Max volume
Frequency response (48kHz bandwidth)
(Note the vertical scale: 1 division = 0.1dB - Black is RME in loopback)
Crosstalk @1Khz @50%
(Tone generator was in 16bits. My mistake.)
Multi tone 1 channel + Crosstalk
Red plot indicates crosstalk. It raises with frequency.
About the difference in noise-limited level in above combined IMD an THD trends:
THD level is measured relative to 1kHz tone level
IMD SMPTE is to be measured against the level of the 7kHz tone, which is 12dB below 60Hz tone
IMD CCIF is defined as measured relative to the sum of the two tones, which are same level.
So we should see indeed, when there is just noise to measure, CCIF 6dB lower than THD, and SMPTE 12dB higher than THD.
That's 18dB difference between CCIF and SMPTE IMD levels, and that's about what we see on the plots.
But THD looks higher (4-5dB higher) than what this theory suggests.
Am I right?
If anyone has an idea why we see that...
Also, I noted that, in the plots showing distortion vs frequency, the levels of H2 and H3 should be higher.
THD is versus signal level, while H2 and H3 are versus 0dBFS.
I'll correct that later on.
Thanks for the detailed and helpful research.
So is it OK to understand that DAC + good Preamp connected to Poweramp is better than DAC directly connected to power amp?
Looks to me as if the actual potentiometer is a standard dual-gang unit meaning that the balanced in/outs are passed through it as single-ended unbalanced signals. Can you confirm this?
A good-measuring analog volume like this one is equal or slightly better at low volume than one of the best DACs.
"Better" is a fuzzy word. The difference is very small, if any.
I guess a device like the Benchmark LA-4 may show a bigger gap (but, given the cost, ...)
The main drawback is channel imbalance at very low level (Which remains very limited here).
I think is not balanced indeed. But I'm not an electronic expert.
I didn't puzzle thru the pictures of the board. If the pots are varying resistance between the plus and minus side of the balanced signal that would still work and stay balanced. You'd need a pair of resistors and the pot between them.
Since it apparently is an active buffer it is also possible the pot is simply varying gain of the buffer op amp and doesn't have signal passing thru it at all. The specs say the input is into an instrumentation differential amplifier.
Understood and that is why I was hoping that someone knew more. I have another similar device (Coleman SR5.1, Mk.II) in which the balanced/buffering inputs and outputs are passed through a single-ended pot.
Looks aweful ;)
Why didn't you do this at 384 kHz sample rate? Fully linear then...
BTW, I assume you use the mono trick at the input to get 3 dB more SNR? Are you aware you can do the same at the output? You can use a simple split cable, two XLR female to one XLR male. Let the generator send out the same signal on both channels. Internal resistors in the ADI cause an unchanged output level and THD, but 2.5 dB less noise. I use that quite often.
Kal's block diagram and a few photos of the PCB suggest it's likely differential input into a TL07x, a mute switch, the pot, a buffer and a balanced driver per channel.
From the manual: "The Volume 2‘s design is based on active switching to avoid nonlinear frequency response introduced by impedance changes with passive designs when changing levels."
Why they say "switching", is anyone's guess.
"High end volume potentiometer and illuminated mute switch from ALPS; the potentiometer controls signals directly (without VCA or DAC circuitry)"
I used to have a volume 8 in my active system some 8 or 9 years ago, but I was not very happy with the channel matching I measured at the time:
Yuck.
