Infinite100
- Joined
- Dec 28, 2023
- Messages
- 12
- Likes
- 6
Pplease donn't appologize.I appologize if this is old news
You did me a bigg favor.
I was waiting for something like this.
Thanks
If you don't mind not using Windows, then Linux could save you those hard-earned dollars of yours.anyways it seems like I'm spending the $5.99 or $8.99 for now.
Hey can i set it up to stream LDAC from pc to 2 separate bt iems?I appologize if this is old news, but I just stumbled across it. There is a bit of software called Alternative A2DP Driver that lets Windwoes transmit LDAC (or other codecs) directly. This assumes, of course, that the computer already has bluetooth capability.
The software lives here: https://www.bluetoothgoodies.com/a2dp/
It is not free. The cost is around $5 for the first computer (perpetual license) and $2 for additional computers. Free to try for a week, though.
The software is more than just a driver. It allows selection of codecs, bit rates, and other tweaks that I have yet to explore.
I am running it right now with a laptop computer streaming to an smsl C200, with nothing but air in between. No hacking was required. I just followed the instructions and it worked as advertised. That just doesn't seem right, does it?
Happy listenings.
gerG
Hello can any expert help?
I can not find out what is going wrong.
Thanks a lot
Hello I check that message through the faq of the site.View attachment 413874
https://www.bluetoothgoodies.com/a2dp/faq/#3rdparty-driver
Did you install a driver for the Max5C?
The other thing you need to be aware of when using Alternative A2DP Driver with a headset (i.e. headphones with a mic) are the limitations...
https://www.bluetoothgoodies.com/a2dp/faq/#microphone
But I can not find out what is going on.
There is any driver form Max5C, and the same happens with my Linkbuds S.
I open windows Bluetooth, I pair the devices and when I open A2DP I get this error.
In device manager I see the devices:
View attachment 413890View attachment 413891View attachment 413892
I have updated every driver but windows said that everything is up to date. Running on Win 10. So confusing, I can not find out what's wrong
my Intel version is new too:You could try uninstalling the Intel Bluetooth drivers and re-installing... https://www.intel.com/content/www/us/en/support/articles/000087250/wireless.html
I thought the driver version for your Max5C's looked very old, but I just checked my 1MORE SonoFlow and it's of a similar vintage (and i'm running a Windows 11 Insider build!)...
I think the device driver version is tied to the MS Bluetooth Enumerator version...
My Intel Bluetooth drivers are much newer...
Yes, when I run with admin rights the buttons are working properlyI've notice that the Intel's Buttons for Update/Roll Back/Disable/Uninstall have grayed out.
