Greetings everyone,
I am going crazy. I don't know if I am just getting terrible luck or if it is something on my end and not the amp. Below is an issue I have had with two of the amps. RMA'd the first one and now maybe even the second.
When using the balanced headphone out I am getting it going from white to red and 'clicking'. This happens at roughly 50% volume on any gain channels that will allow for that volume to be reached. This happens without even a headphone plugged in. Just the cable from the amp. The cable I am using the Periapt argon balanced cable and modhouse argon mk3s. I have tested the cable with a multimeter and everything is good there. The second cable I have is an xlr headphone adapter to 2.5mm, I got a TRS 2.5 - 3.5mm to test the audio. The problem persists. I have tried the following tests to see if any option is causing it:
One thing is that the left channel is heard but not the right only in the adapter configuration. And when it clicks it goes from very brief right audio to no audio in but the 'full sound' is gone even with the brief dual channels. When I crank the volume the left channel does have the right volume but just cut out. Single ended output channels are OK and function great.
I have recorded an example of what is going on here. I am raising the volume on my keyboard to trigger the 'clips'.
I reached out again to Massdrop and I am hoping for a solution. Does anyone have any idea? I've spent hours trying to figure this out, I love the sound of the THX.
Thank you for your time,
Karl
- Used balanced Enog2 Pro dac with balanced out and optical in
- Used balanced Enog2 Pro dac with RCA out and optical in
- Used Schiit Modi2 Uber Optical in, RCA out
- Used Schiit Modi2 Uber USB in, RCA out
- Used different RCA cables
- Tried different balanced to headphone cables
- Plugged in different power strips
- Plugged directly into the wall
- Separated THX from dac in two separate wall outlets (different sides of room)
- Used different computers for source (both USB Schiit Modi2 Uber)
- Tested all steps with and without a headphone plugged
Karl
