I am running an SMSL SU-8 balanced output into the Loxjie P20 (the unbalanced from the SU-8 goes into an Atom).
I have converted a pair of Beyerdynamic Custom Studio to balanced by replacing the 3.5mm TRS with a 3.5mm TRRS wired:
Tip: L+
R1: R+
R2: L-
Sc: R-
I have also made two adapters, the first is to convert the TRRS (at amp end) into a 1/4" TRS for Single ended use, this is wired:
TRS ------ TRRS
Tip ------ Tip (L+)
Ring------ R1 (R+)
Screen --- R2 + Screen (L- and R-)
The second adapter is to convert the TRRS to a 4 pin XLR for use with the Loxjie P20 balanced output. This is wired:
XLR4 ------ TRRS
Pin1 ------ Tip (L+)
Pin2 ------ R2 (L-)
Pin3 ------ R1 (R+)
Pin4 ------ Sc (R-)
I have tested all of these connections and the all are correct with no shorts.
When connected to a single ended output (using the TRS to TRRS adapter) they work fine on both the Atom and the SE output of the Loxjie. However, when connecting the headphones to the balanced output of the Loxjie P20, I get a very weird sound that sounds like a combination of out of phase and slow motion, as if everything is happening a lot slower.
I have also tested the output of the Loxjie to make sure there are no shorts between cores on the outputs, but that seems to be fine also.
My question is, even though I have already tested connections multiple times, if something was indeed out of phase, wouldn't this also affect the headphones when running in SE mode? I mean, if a + and - was crossed somewhere in my connections, then it would be crossed when using SE also.
Is it possible that the wiring of the Loxjie balanced output is different to that stated in the manual?
Any suggestions on what to test would be greatly appreciated!!
Thanks in advance.
Tip: L+
R1: R+
R2: L-
Sc: R-
TRS ------ TRRS
Tip ------ Tip (L+)
Ring------ R1 (R+)
XLR4 ------ TRRS
Pin2 ------ R2 (L-)
Pin3 ------ R1 (R+)
Pin4 ------ Sc (R-)
Thanks in advance.
