This is where my skepticism immediately starts kicking in. He may be a respected speaker designer, but has he actually tested this? The notion that vibration from the speaker's enclosure is not only strong enough on its own to travel through the flooring to your seat in a noticeable way, but to do so via the speaker's feet seems unlikely to me. It seems way more likely that you're going to get way more coupling to the floor through the air, since that's where the vast majority of the speaker's energy is going.highly regarded speaker designer PAUL BARTON of PSB talks in this video interview about the nature of coupling and decoupling speakers from vibrating wood floors. Starts at about :50 minutes:
He points out that vibrations from a loudspeaker sitting on a wood floor (such as the one he describes) is going to cause sound vibrations to move through the floor to your seat where you will feel it.
If that is the only thing you're looking for. All valve-based gear shows a marked improvement in tube longevity.Evidence show me the evidence, if the footers audibly changed the sound then that will be measureable.
Sad to say, you need to do a little more research before making a statement like this. One of the most outdated areas of engineering is in the music reproduction industry. Vibration control has been used in every major industry involving moving parts. What on earth makes anyone think that equipment, along with speaker cabinets, is somehow immune to studies that have been going on since they first added springs to chariots/horse and buggy, and then on to motor-driven vehicles?The notion that vibration from the speaker's enclosure is not only strong enough on its own to travel through the flooring to your seat in a noticeable way, but to do so via the speaker's feet seems unlikely to me. It seems way more likely that you're going to get way more coupling to the floor through the air, since that's where the vast majority of the speaker's energy is going.
Please show me the research that shows that a significant amount of energy couples from a speaker cabinet to the floor through some little feet, and which requires elaborate "decouplers" to avoid. Also I'd like to see how this compares to the amount of energy that couples from the speaker to the floor via the air. Until then, sad to say you have no more of a leg to stand on than I do.Sad to say, you need to do a little more research before making a statement like this. One of the most outdated areas of engineering is in the music reproduction industry. Vibration control has been used in every major industry involving moving parts. What on earth makes anyone think that equipment, along with speaker cabinets, is somehow immune to studies that have been going on since they first added springs to chariots/horse and buggy, and then on to motor-driven vehicles?
And what actual physical medium could possibly cause that Matt?
Why do you so desperately want to believe in BS products?
I can't recall if I saw that old thread. Was it determined if the materials you were using were resonating themselves?I was reminded looking at my old thread on trying stuff under my speaker that at one point a certain combination of materials was causing overblown bass to the point that for the first time I was having the problem with an audibly rattling grill on one of my speakers. But when I used certain other materials the bass was more controlled and the rattling stopped. It was very repeatable.
Rattling grills… quality product!
‘How I fixed my rattling grills and it only cost me £1000!’
Any subjective site would lap that up.
Nice, seems to confirm my suspicions that there just isn't enough energy in the speaker cabinet (at least a decently built one) to worry about it coupling to the floor (or whatever surface it's sitting on). Any actual audible change seems to be due to movement of the speaker itself, whether just the height from the isolation product itself or inadvertently slightly changing the position while installing the product, which of course we know certainly can make a significant difference.Check this: Speaker Isolation.
Believe me, when you're talking about Paul Barton, I can guarantee that he has tested it. He was one of the first people to test all of his products in Canada's National Research Council anechoic chamber. If you don't believe his ears, that's fine, but I'm sure he arrives at his opinion after quite a bit of listening.This is where my skepticism immediately starts kicking in. He may be a respected speaker designer, but has he actually tested this? The notion that vibration from the speaker's enclosure is not only strong enough on its own to travel through the flooring to your seat in a noticeable way, but to do so via the speaker's feet seems unlikely to me. It seems way more likely that you're going to get way more coupling to the floor through the air, since that's where the vast majority of the speaker's energy is going.
Precisely what we found when we measured just not enough structural transmission despite playing extremely loudly and as the company stated there is still airborne transmission to consider.Check this: Speaker Isolation.
No. Acoustic measurements weren't provided. Despite the fact the phenomena is eminently measurable and measurements were asked for many times. About halfway though the thread it was seen that the height, angle, and position of the speakers was being changed with the different materials. How that affected actual sound is a guess, but as we know speaker position in room has a large impact on sound. So run to run was not controlled, and sighted listening was the measurement method.I can't recall if I saw that old thread. Was it determined if the materials you were using were resonating themselves?
www.audiosciencereview.com
Exactly. The problem is the radiated sound of the speaker is what couples to the floor. I've also measured different feet on hardwood floors of our old house.Nice, seems to confirm my suspicions that there just isn't enough energy in the speaker cabinet (at least a decently built one) to worry about it coupling to the floor (or whatever surface it's sitting on). Any actual audible change seems to be due to movement of the speaker itself, whether just the height from the isolation product itself or inadvertently slightly changing the position while installing the product, which of course we know certainly can make a significant difference.
