you're entitled to your informed opinion.as am i. make sure you have your own evidence to work from. i have mine.No, this is not a matter of opinion. There's plenty of evidence that all this concern about coupling or not coupling speakers to the floor makes no audible difference. There's just not enough energy going into the enclosure. You'll get drastically more of a difference changing the speakers' position by a few mm.
If you believe that sticking some granite under the speaker will have some meaningful impact, the burden is on you to demonstrate this. It's not everyone else's responsibility to debunk every random notion someone has with no evidence to back it up or even a plausible mechanism for how it would work.
were you in my house, you'd hear the difference, though, i personally decouple rather than isolate.
im no scientist, engineer nor did i take any measurements. i stand by the differences it makes as i hear them and thats all that matters to me.
at the very minimum, my friend, i spent a whole year trying different materials and combinations to come up with my solution. i can tell you that any and everything you use will have some sort of effect. i can tell you that you'll hear the difference between mdf and any wood without need of measurements. and that's just wood products.
rubber. rubber and cork or sorbothane, sorbothane, all have an effect you'll hear. sorbothane sucked in my system. dulled the overall presentation.
the burden of proof. my floor is carpeted wood. before i did any experimenting, i could hear the floor and walls resonating whenever i got even close to loud. i could hear it in my apartment hallway, on the bottom floor, if it was loud. i went looking for solutions to boom and thud.
i researched isolation, dampening, decoupling, anything that might help. i had a few conversations with a guy using granite plinths to see why he used them.
i started with different rubber feet and moved to svs sub feet. i tried rubber and cork pads. rubber and sorbothane, sorbothane.
i tried different woods, mdf, and thicknesses of. i tried woods and rubber of all sorts.
after reading about dampening. i tried it using a concrete paver to act as the floor. thinking it would dampen speaker resonance through the floor. very good response. but, i felt there was more to be had. i had some horsestall mat left over from a deadlift platform i built and tried it under the towers. then wood. wood and mat. the pavers and mat by far gave me the results i was aiming for. the subs on isoacoustics sub stands for the subs.
it sounds great. i can turn it up louder without it bleeding through the floor and walls. i can no longer hear it in the hallway unless im above 75-80db, and you have to stand in front of my door.
bass is solid, detailed. midbass improved. smoothed the highs some. and overall. im happy.
whatchu got?
