I’ll say it again: LS50 does not need 250W. You will destroy the speaker with 250W. MaxSPL is reached with less than 100W. If you want to play loud, get different speakers. It’s only a small 2-way. They are not designed for that. Now if you would like to update at some point I can understand that you want something extra. Just don’t do it for these speakers alone.
Also not given is the budget for all this? Would be nice to know.
I don’t think you’ll find a one box solution for this. It will always be a highly compromised solution. You’re basically looking for something that your Schiit preamp should have solved. Split the processing and the amps is the most sensible solution. MiniDSP has several solutions that might suit your needs, Then just get some of the earlier mentioned small amps.
Maybe this amp will suit:
www.audiosciencereview.com
Plenty of power, should run fine at 48V, pffb. Obviously not as cheap as many of the other options, but really solid performance. More than you would ever need. Otherwise, don’t obsess too much on PFFB. With processing you can fix the frequency response errors easily. More and cheaper options are then available.
Well, you really haven’t given us much context, so then I will try to extrapolate from what is given. You basically want all the features a modern AVR has, so yeah, that would still be my recommendation. You don’t have to like itWeird telling me what I want.
3e audio A7/A7 Mono Amplifier Review
This is a review and detailed measurements of the A7 / "A7 Mono" stereo power amplifier with balanced inputs. It was sent to me by the company. I have no idea what it costs in US. Audiophonics lists it for 379,00 €tax incl. While the A7 may look like its competitors, it has a heft to it that I...
