ISO Cheap(ish) Multichannel DDC gadgets? e.g. RPi inputs
john61ct
Looking to easily get multichannel streams into and from various A/D D/A converter devices not necessarily investing in full blown interfacii.
Hifime UR27, TOSlink to USB output, is an exemplar but that is stereo only
Ideally looking for 8+ channels
My current use case is inputs to Raspberry Pi, both RPi4B and RPi5
but really while we're at it, whatever the use case, whatever the formats not just USB and TOSlink
but also ADAT, S/PDIF even AES, I2S HDMI (yuk)
Ethernet stuff too if applicable, currently AVB is my hobbyhorse using RPi5
Ideally finished gadgets plug 'n play OTS, rather than making enclosures, extreme component level DIY, soldering etc
but please, **brainstorming mode**, post whatever comes to mind, as long as NOT just one or 2 channels,
and really looking for DDC functionality, A/D conversion is OK but not gadgets that do only that.
And finally, yes not necessarily "cheap", but that would be ideal.
If you search Amazon for "multichannel external sound card," you'll find a bunch of things like this one that are 7.1 channel, though I can't speak to their quality. There's the Creative Soundblaster X4, I've never used it, but was tempted to give it a shot. There are a lot of audio interfaces that have 8 or more outs, the Focusrite 16i16 is like $400, the Topping E8x8 is $450, MOTU Ultralite is getting a bit more expensive around $650, and on from there. One thing I considered was getting a Mac Mini from 2012 with Firewire output for like $100 since you can get older Firewire audio interfaces on the cheap now. I assume you've considered the hifiberry dac8x since you have a Pi? I tried it but couldn't get it to work without a bunch of noise, I'll send it to you along with the case if you want to give it a shot. Getting higher in price a used Exasound e28 can be found for less than $1k these days. I managed to snag a Fireface UCX II for a good deal, but it still wasn't cheap. I've wanted to return it on a number of occasions but I now have Stockholm Syndrome with TotalMix and have learned to respect and obey love it, yes love it is what I meant
Yes USB to SPDIF fits, thanks!
However pretty sure "sound cards" = interface
not what I'm after, collecting DDCs in this thread
miniDSP U-DIO8
yes fits the thread perfectly.
two models, U-DIO8 S/PDIF vs AES/EBU
Multichannel USB Asynchronous interface with up to 8ch input & outputs
4x stereo in, 4x stereo out, total 8x bidirectional digital only channels
no digital ports onboard other than USB
DB-25 connectors, standard TASCAM pinout
Not a fit for my use cases, but that's not so relevant here, mainly for capturing a list
RME Digiface USB, technically an interface but all-digital so I'll allow it.
of course brilliant, flawless with Linux
if you have secondary ADAT based "breakout box" converters,
or full primary interfaces if they do not work easily or well with your host, can work via ADAT in "standalone mode"
but at a cost, RME Digiface USB is not so cheap, as to be expected, with support for 66 total physical channels.
