ISO cable for OG RME Digiface HDSP CardBus/PCMCIA connection
john61ct
My goal is not recording or mixing / producing music, but a high count of multichannel DSP and crossovers for recreational reproduction, cheap.
If members have other similar gear sitting in closets, or alternative suggestions feel free to speak up.
In this case I like the RME OG Hammerfall Digiface ability to expand via ADAT.
There is an apparently proprietary cable to connect that Digiface to a PC (usually laptops) Cardbus / PCMCIA card, and I have not been able find one.
I would alternatively be interested in buying a Card + cable from someone who kept them together.
And/or the PCI version, WITH THE CABLE.
I believe there never was a PCIe card for that unit?
Of course the Digiface USB would be 10x better, I've not found used instances I can afford.
https://www.audiosciencereview.com/...gh-sq-but-cheaper-than-rme-digiface-usb.71592
https://www.audiosciencereview.com/...a-or-layla-24-host-adapter-cards-cables.70681
https://www.audiosciencereview.com/...d-value-for-pc-i-o-as-echo-audiofire-12.69743
