Pancreas
- Joined
- Nov 2, 2022
- Messages
- 481
- Likes
- 96
Actual surround is to have several speakers and subwoofer around you to create that surround experience. What's the point of a virtual surround switch on your PC, audio card, consoles, etc if all you're using with is a soundbar, or built-in speakers on a monitor, or a couple of speakers?
How can this "plugin" bypass physical limitations? It can't. No amount of virtual surround, is going to create a surround experience if all you have is a soundbar, is a gimmick.
For headphones, it may be different, even then is not actual surround. It may change the sound slightly or different, doesn't mean is better or actual surround.
For example. I have two Genelec 8030c speakers connected to my Scarlett Solo audio interface, then interface connected to PC.
How can I get "virtual surround" with my PC or audio interface. There is no option. Even then, it wouldn't be real surround anyway.
To get real surround with your PC/studio, you would need buy an audio interface with enough TRS inputs such as Scarlett 18i20, then buy a least 3 more speakers and a subwoofer, connect everything to the audio interface, position the speakers around you, then and only then, you will have actual surround sound experience.
How can a virtual surround create surround when is limited by a soundbar or a couple of speakers? It can't. Therefore, is meaningless and pointless. Its a gimmick.
Example of actual surround
Another example of actual surround would be a Bose system in a vehicle, where it has 10-11 speakers, then you would have actual surround coming from all directions
