Is topping NX4 the best desktop option sub $200?
Kosta
New Zealand
Looking for a desktop solution . Have ruled out modi 3 plus jds atom as after shipping they are pushing 250+.
After the NX4 anything else worth considering?
digititus
NX4 isn't really a desktop solution. More for portable use.
K
Kosta
New Zealand
yep I realize that, but looking over objective + subjective reviews looks like its the best performing option across both classes in this price range . Note i'll be driving Senn HD58x .
mi-fu
New York
For desktop use, probably the best option at that price range would be Topping D50s.
Veri
As a DAC+Amp it is pretty good, yes. But since it is battery powered it is maybe not the ideal desktop device.
digititus
Have you looked at any of the SMSL offerings? The SMSL SAP-10 would fit your budget. Hasn't been tested here, but looks decent on paper.
Edit: Just an amp
K
Kosta
New Zealand
Another option would be the dx3 pro but unsure about the v2 version as they changed the headphone amp which changed the specs and this version hasn't been tested here
August
I think 9038s or the upcoming 9038d is worth considering.
bunkbail
I'd give E1DA PowerDACv2 or #9038S a shout.
Enkay25
My two cents:
NX4 DSD is more than good. Why? It can be for both world - as a portable and a desktop dac. It is only limited by the input choice (s).
I own one. And quite happy with the performance. I connect it with the additional usb for power/charge....at desktop mode :)
Baphomet
Mmmmm not really, the 58x is slightly easier to drive than HD600/HD650 (which aren't that hard to drive!). NX4 will do fine.
That was my point exactly. I was just saying that down the line he might get different headphone which requires more power. So for roughly the same money D10+Atom is more future-proof.
cidel fastro
I'm facing the same dilemma got hd 58x looking for dac amp combo around 200$. indecision between the dx3pro v2 vs fiio k5 pro both not measured yet..
