Is this list that I made any good?
I have found some interfaces in the 100 euro's pricepoint, help me choose.
  • Arturia MiniFuse 1
    Votes: 0 0.0%
  • Steinberg UR12
    Votes: 0 0.0%
  • Tascam US-1x2HR
    Votes: 0 0.0%
Oli4_
Hello,
First, if this is posted on the wrong category, I am very sorry... I am a newbie.
I want to upgrade from my USB Mic and want to go to a XLR setup.
I also want a new pair of headphones, closed back and I listen to rap, hiphop and game a little.
But there is so much choice between mics, interfaces and headphones that I just can't choose. Like many persons say that this interface is better, that headphones are better etc.
I already made a list but want to have a list of you guys, so that I can maybe change some things.
My budget is 160 euro's, i can go above a little and I am buying it off Thomann.
I will use the microphone just for talking with friends, streaming and maybe a podcast.
I already have a mic arm.
This is my list.
Please let me know if I can improve something, like maybe the interface.
Seems like a good starter interface package for what you're looking to do.
The UMC22 is a bare bones interface, but should have adequate gain for the mic you have selected.
I checked Behringer's website and could not find the mic input gain, but I'm guessing it's around 55db.
The ATH M30X is a good headphone with decent bass response for your choice of music.
Welcome!
This isn't something I know much about, but hopefully you can get some good suggestions. Lower cost gear is getting better and better.
Well, I can go above budget with the interface, the only option i saw was the UMC22 because Windows just installs drivers automatically which do not have problems like the focusrite. I read that the focusrite has a lot of issues with drivers that cause clicking, popping etc with voice chat applications. I want to go above my budget a little for a better interface. If you know a better one, please let me know! Thank you very much.
If you are in Germany have a look at ebaykleineanzeige, from time to time shows up one of these bundles focusrite sells (scarlett 2i2+mic+headphones) for around your budget. Don't know if the same exists with the solo.
Focusrite products are generally solid and I would not worry about it - I have a 2i2 V2, and I've dealt with a whole bunch of 2i2 V3s. I've actually had far fewer issues with them than with the Behringer interfaces I deal with.
MOTU also sells a really good interface (the M2) which is probably a little better than the 2i2... but last I heard they were pretty hard to get (supply chain dumpster fire being what it is).
Also, and this may or may not matter to you, Behringer isn't exactly the most ethical company in history... do some reading and decide if it's a company you'd feel comfortable supporting. I know I don't feel good about buying from them.
Yeah, motu M2 is a little bit too far from my budget. But I am thinking about the Focusrite Scarlett Solo 3rd gen.
The ethical part of the company does matter to me.
Thanks!
Yes, there exists something for the 3rd gen solo.
Reactions: MCH
Also, I am not in Germany, but in Belgium.
I do not like used products. Especially mics. Not so hygienic...
But thanks!
Just spray with isopropyl alcohol.
...The worst is when you see ads for amplifiers and the knobs are coated with shit from the dirty person's fingers. WTF.
Especially if you see some yellow, brown gunk :facepalm:
But my preference is a new device, i've made a poll of 100 euro's interfaces. Idk which one to choose lol
:) ^^That's the problem with internet consumerism. More options and information overload.
Yeh, that colour ranges from yellowish through brown to black. ...and can form a sort of halo around the on/off button. ...Vintage...
You need to figure out what features you want from an interface. Search for interfaces that meet your criteria.
Number of mic inputs ? 2 should be enough, since you're looking to use it for podcasting/gaming
Do you need instrument inputs ? Do you plan on recording musical instruments such as electric guitar ?
Bit Depth/Sample Rate ? 24 bit/48khz is adequate for podcasting/gaming
Mic Input Gain ? Minimal of 55db, 60+ would be nice for low output dynamic mics.
Class compliant interface or will it need to have custom drivers installed ?
Max Price Range ?
Max Price Range ?
Hello,
Thank you for your reply.
- 1 is even enough now. So like one XLR input
- I am not planning on recording muscial instruments or something.
- 24/48hz would be nice
- 60+ just wanna more headroom
Max price range for a interface itself is 105 euro's, I've made a poll of some interfaces of that price range.
!!!! I do have a ryzen cpu based system, i've heard that some interfaces have some problems with Ryzen.
So,
Everything summarized.
I search a interface which i am gonna use ONLY for discord and livestreaming. I want to upgrade from my USB microphone. So just one XLR input is enough
I am not planning on recording musical instruments.
I want a higher Mic Input Gain for more headroom in the future, also I want to be sure that the company will develop drivers for a while.
Max price I want to pay for the interface is 105 euro's.
Hopefully I gave you guys some more information of what i want.
The Focusrite Solo is not a bad choice for what you are looking to do.
The place this is most obvious is on the rubberized knobs that Agilent started using in the late 1990s. You can clean most of that grunge off with isopropyl alcohol on a cloth.
