Ruh Roh:
Do this first:Ruh Roh:
Those numbers in the chart line up almost exactly with the distortion measurements, which means I'm just hearing the Kali's signal distortion. There might not be any noise here but rather not good enough distortion performance.
Should I save up for the Neumann KH150s now?
Hard to say what it might be. My experience is that almost all speakers and speaker chassis create harmonics and sometimes additonal noise when driven by clean sine waves around 500 Hz to 3 kHz. With music this is not really perceivable. Although the overtone of your recording is not matching the 440 Hz harmonics frequency it looks like a 3rd harmonic in the Musicscope analyzer software.This happens on both speakers.
Enjoy!![]()
Hearing distortion at -55dB down shows good listening skills... but yes, what they don't tell you is good listening skills destroy your budget and peace of mind.On one hand, it's nice to know I can hear such little distortion. On the other hand, it's not so nice to need to go to the top to get something acceptable.
I did some testing at lower frequencies and I could still hear a little of this annoying distortion. Could it be that third harmonics tend to sound worse than seconds because they tend to be at higher frequencies?Seriously now,this H3 is not much it's just happens to be in a very sensitive ear area.
Anything there can point out with the right conditions.
To tell you the truth what I hear in your file is not the H3 but some faint rather uncorrelated noise,disturbance-like.I did some testing at lower frequencies and I could still hear a little of this annoying distortion. Could it be that third harmonics tend to sound worse than seconds because they tend to be at higher frequencies?
I checked this again and I can't actually find any evidence of this noise even though it definitely sounds like there's one. All that exists is the main tone and the faint harmonics, and the rest of the noise in the room.To tell you the truth what I hear in your file is not the H3 but some faint rather uncorrelated noise,disturbance-like.
Well yes, they are. Here's spectrum of 5 seconds starting from 7th second, H3 is ~70 dB below the tone:It doesn't totally explain why you perceived changes in pitch with changes in volume, but if different harmonics were becoming dominant at different volume levels, I dunno, maybe that could be it?
I dunno, the harmonics look pretty clearly visible there when you turn up the volume. Would not be surprised if they were audible. And the frequencies are cut off but you have some kind of high pitched tone way above the tone and harmonics...?I checked this again and I can't actually find any evidence of this noise even though it definitely sounds like there's one. All that exists is the main tone and the faint harmonics, and the rest of the noise in the room.
The distortion spectra look a bit different, but then again the drivers will also have different frequency responses, so I think it's hard to say.I hooked up three different woofers (some peerless 6", dayton dsa135, and dayton dc130) to the kali amp and close mic'd them running the 400hz tone. Here's what I got. Is this enough info to conclude that the distortion is coming from the amp or is it just harmonics of the drivers?
I would say the 3rd harmonic looks unusually high in all cases but it's not a smoking gun.
I think the thing to do in this case is measure the output of the amp directly using an ADC. However, I don't think most ADCs are capable of handling multi-watt inputs. Amir's tests handle this but his measurement gear is super expensive. Not sure what I'd do next here.
