First of all, I would like to thank everyone in this website. I'm definitely learning a lot from all of your advice and posts.
Sorry for bothering you with more newbie question but can you sit TOO CLOSE to your monitor speakers (Polk R200 to be specific)?
I've been watching videos on YouTube and it seems like there are some general "rules" that I should follow:
1) You should keep at least about 1ft (30cm approx.) distance from your speaker to the front wall.
2) You want to keep equal distance between your speakers and the side walls.
The maximum distance from the front wall to my ears is 120cm. (The bed cannot be moved)
So, while following the 2 rules above, 120 - 30 (1ft) - 35 (approx depth of Polk R200) = 55cm.
My speakers would be only 55cm away from my ears and the distance between the speakers would be 55cm too.
If I follow the general recommendation of keeping the equilateral triangle between me and the speakers like the Diagram 1, I have no other choice but to keep both monitors super close to each other, thus sacrificing stereo imaging effect (if I'm correct).
However, if I separate two speakers apart more from each other, I might be able to enjoy stereo effect more than the Diagram 1, but now the triangle has changed into an isosceles triangle, not equilateral. Moreover, I don't know what kind of negative effect this will bring.
TLDR: What speaker placement is better for mixing music? Diagram 1 or Diagram 2?
