And sources on that?
This is FAR from not peaking in the 3kHz - 5kHz range - neither FF, nor DF, in fact it's completely the opposite.
Please elaborate on that?
See the old Tyll's article. Tyll's HMSII ear simulator had almost -10dB compensation between 3-5kHz to account for the specifics of the head.
Sonarworks posted in
an article that the HF attenuation should nicely even up with room reflectivity.
B&K 1974 target -
originated probably here - is mentioned as merely accounting for getting the FR properly into the shape of near-field and far-field response? It makes an assumption, that the microphone catches both reflected and direct sound w/ flat (or near) manner - which is a realistic one to be done. Thus we'd need to consider rolling off the HF to emulate the realistic balance - keep in mind, that it was written in 1974 and regarded a specific scenario, since they mention targeting an "average hall" but with half intensity of rolloff. And yes, the reflected sounds in rooms are an issue, which cannot be accounted for easily. Still, the paper in itself is old and amounts for 1) the materials used to build homes back in the '70s (which means that the curve might not translate to modern rooms) and 2) well, they write explicitly that the point of interest was between 60Hz and 6kHz...
It'd actually be easy to recreate the B&K from Harman (if we consider it perceptibly flat, disregarding the bass boost) - merely treat Harman as flat & overlay that respones to look like B&K. Since the basic curve itself (w/o bass boost) was derived (afair) from speakers EQ'd to measure flat in-room response in a reference room, then overlaying B&K should amount to just overlaying.
That one is actually a great question! In
A Statistical Model that Predicts Listeners’ Preference I see no mention of such comparison. It'd be an interesting one to see whether the applied curve lends itself to being measured as flat in-ear. I don't actually think that they're after that kind of experiement, seeing how far this is into supplying something that just sounds satisfying to mostly anyone.
On ResearchGate I can see Olive et al. paper called "Listener loudspeaker preference ratings obtained in situ match those obtained via a binaural room scanning measurement and playback" - it seems distantly connected.
Seeing that Harman Curve sparks discussion (albeit one really tinged into Reddit-like or even insulting territory, which is saddening, seeing how we'd like to discuss the matters to measure and not whether one is deaf), I'd like to delve into something I've noticed today:
In The Ultimate Paper (TM): Olive et. al.
A Statistical Model that Predicts Listeners’ Preference they've used the (by now it seems standard) methodology of EQ-ing the K712 and convoluting other headphones FR's onto the K712s. So, they must've measured K712s on GRAS, then applied a differential EQ between K712s and measured pairs. EQ'd K712s to 30 pairs + one "high anchor" (Harman Curve) and measured preference across listeners.
The idea of virtualizing headphones over each other came from the idea before, based on (their own) papers concerning the blind-testing case on headphones. It's obvious that perception can be skewed by what you feel on head and that might get all the typical bias-train going. To avoid that, you'd have to virtualize what's on head. Also, what was mentioned before: they explicitly state that the match was within +-dB up to 12kHz; so we're actually talking about tonal balance of different pairs, but with K712s 12kHz+. Does that show any red flags? It's interesting, to say the least. Now, that
could pretty much tilt the favour into Harman-EQ'd K712s side, because of merely emulating the rest badly. Hmmm....
The virtual headphones only simulated the magnitude and minimum phase part of the headphones and excluded any nonlinear or excess phase distortions that were present in the actual headphones. However, the validation studies together with other headphone investigations suggest that the magnitude response is the dominant factor in how good or bad a headphone sounds.
... and as commented in conclusions:
Finally, we wish to address the limitations of this study so that the results are not generalized to conditions outside those tested. This study did not address or simulate non-linear or excess phase distortions. Ourexperiences and others suggest these are not dominant factors in how a headphone sounds, but more research may change our views.
As such, they're aware that they're not accounting for this.
As such, it would be good to know whether EQ-ing into a foreign characteristic doesn't cause new non-linear issues to occur and distortion to happen, thus lowering the preference rating perceived by the listening group -> in the end, the preference rating could be different when faced with a "real" pair, accounting for the non-linear phenomena that the specific FR in a specific enclosure causes. It is
not mentioned, however, whether they've checked for distortion happening after EQ-ing.
There's an interesting paper dated 2017/2018:
doi: 10.1121/1.5031030 (
Perception of nonlinear distortion on emulation of frequency responses of headphones). It seems - please correct me if I'm wrong - that what they've done is pretty convoluted: forcing 11 pairs to emulate HD800's response and afterwards measuring their FR & non-linear distortion. Then, bending HD800's FR to match what was measured on pairs & emulating the measured 2nd & 3rd order distortion. Oof! I don't know whether it seems trustable, but interesting nonetheless. Despite that, it seems that what is lacking is the comparison of starting vs resultant non-linear performance, but that's not what the study was after, it seems. And it's all about detecting 2nd/3rd order distortion by ear, not exactly whether it causes anything bad to happen.
The previous work of Gutierrez also seems interesting:
doi:10.3390/app6040117 (
Influence of the Quality of Consumer Headphones in the Perception of Spatial Audio). Conclusions are regarding the proper (1dB or more) channel balance, FR uniformity & quality, uneven response between 100Hz & 1.6kHz causing front-back confusion (widely mentioned in opinions of some pairs!) and 4-7kHz causing bad lateral positioning.
It would thus be of interest to get the the oratory1990 EQ god to measure more than merely the FR... There might be a gigantic bag of conclusions to be found there.
