Is there any point in buying a SMSL po100 or equivalent for PC to AVR audio?
Zerothezone
I'm currently using a generic random usb to optical converter and just heard of the SMSL. Is there a point in "upgrading" this? I previously didn't think it would affect much but apparently I saw SMSL with such a product. My current converter is limited at 16-bit/48 kHz.
SPDIF Optical is a robust digital interface, so even cheap converters can achieve flawless sound quality, as long as they are solidly designed.
That being said, if you buy a <$5 generic no-name converter from AliExpress or the like, then you can encounter things like extreme jitter, signal truncation/faulty resampling, or low volume caused by shoddy firmware or PCB design.
I have personally measured my $30 SMSL PO100 to be bit-exact, and therefore would not spend more than that on a converter.
There's none of this in mine just that... its locked at 16-bit/48 kHz, so I'm say, not getting the native bitrate from tidal through.
On the plus side you won't have to worry about what happens if you send a sample rate and/or bit depth the receiving end doesn't support.
