- Thread Starter
- #21
Wait...wait wait....do I need speakers too? :OOOAmplifiers have no sound. The sound comes from speakers and their interaction with the room.
hmm. After reading the owners manual for the Rotel and CXA I am concerned the subwoofer out is just a low pass output and there is not actually an active crossover configurable in the settings for the integrated amp. Which means, IMHO, they are all missing a critical feature to separate the low frequencies out from the mains and send them only to a subwoofer. If so I personally would skip them and find a stereo integrated amp that handles 2.1 correctly.
So my question is: What speakers do you plan to run? Do you plan to add a subwoofer? If you do then I would find an integrated that properly handles subwoofer crossover configuration.
For the CXA I would pair it with Dali Oberon 7, whereas the Rotel/JBL I would pair them with Dali Oberon 9.
I didn't consider adding a subwoofer into the configuration. Excuse my ignorance but I thought that subwoofers were a home-cinema A/V component and not really necessary (not even needed at all) for a 2-ch Hi-Fi system. Now, with all these comments I see the case is different.
I think that both Dalis have some sub- capabilities though...not sure.
All amps sound the same until they clip.
What I've been learning from all the speaker reviews and the Harman research presented on this site is that bass response and getting full range audio performance is a big impact on personal enjoyment. For example if you look at the speaker reviews when the preference score is calculated, it always goes up significantly (E.G. 1+ full points) with a subwoofer. Which is code for telling us, we'll enjoy our stereo systems a lot more with good low frequency performance.
Now when working backward from that, when you read the speaker measurements they are always limited first by their low frequency performance. they distort much more first at low frequencies. To exacerbate that problem, we need A LOT more power to create those low frequencies AND we need the SPLs to be much higher for our ears to perceive them at the same loudness as mid-range and highs. E.G. 110db at 25hz is the same perceived loudness as 80db at 3Khz. So it's a double whammy for us to get the HIGH SINAD sound we are looking for with full range.
If you think about it, it makes intuitive sense. We are trying to make a mechanical device move a larger distance and a larger amount of air very linearly (no distortion) to create low frequencies. So that will take more power than moving a very small tweeter a small distance to create a high frequency.
Hope that is helpful.
I am quite new to the forum and as I am trying to build my first Hi-Fi system I was wondering how much different is the sound quality/experience amongst cheaper to more expensive amps.
Its true that subwoofers are still not commonly used or accepted by a lot for 2 channel systems, but this does not mean it is optimal to not use them . In fact, just the opposite is true. One of the basic foundations for high fidelity is achieving a smooth, accurate, +/- 3 dB response full bandwidth(with correct downward slope) so that all frequencies are played back at the correct level. Two speakers alone in a room are not high fidelity. Response below 300 Hz will be a +/- 10-15 dB train wreck, highly coloring everything played. Main speakers are placed symmetrically on the front stage which is often or almost always not the ideal placement to achieve a high fidelity response below 100 Hz. The solution is a pair of well placed subs properly crossed to the mains at around 80 Hz with bass management, time alignment, and eq on everything up to 300 Hz or so(Schroeder). High fidelity equipment should have this capability, or it is just not high fidelity, but rather just dated and behind the times.For the CXA I would pair it with Dali Oberon 7, whereas the Rotel/JBL I would pair them with Dali Oberon 9.
The take home message from the graph, linear sounding moderate increases in loudness (Sound Pressure Level SPL) require exponential increases of wattage. While many speakers in the home will do about all you need with a good 100 watts, getting on up that little bit extra easily eats up several hundred more watts.@Beershaun it looks beautiful! In the UK we have it for £4,000...quite a steep increase...I also like the fact that has expansion slots, didn't even know that this was a thing.
@RayDunzl in other words, for the noob, the difference becomes evident when I start playing the music really loud? I see an exponential increase and linear increase in the plots (I am a statistician in profession) but unfortunately I do not get much else.
Me, as well.This forum is school for me!
