I am sceptical that there have been major advances over the Salon2. But there’s also some wild and ambitious loudspeaker designs out there. I wouldn’t be surprised also if some of them offered certain compelling experiences over the Salon2, depending on what somebody’s goals are.
I think that's the most reasonable assessment. If what you want is a wide-pattern full-range forward-firing monopole (and that seems to be the sweet spot for most listeners) then you probably won't do much if any better than Salon2. Even if you consider well-executed speakers with similar design goals but much higher pricing,
e.g. the big TADs or Vivids - which, come to think of it, aren't even that much newer, if at all. (KEF tend to be narrower dispersion than Revel/TAD/Vivid. Same applies to Genelec/Neumann.)
Now some of the modern cardioids are certainly interesting, and may have upper bass advantages in some or even most rooms. But they're also not as wide in pattern.
FWIW when we were looking speakers for a 2-channel system ca. late 2021 I surveyed the field, and landed on Gem2 - which is basically mostly the top part of Salon2, but with an 8" midbass instead of 6.5". And a cruder baffle, I don't recall ever comparing their measurements until today, and pulled the spins because I thought they may show how Gem2's less sculpted baffle may appear less resolving or transparent in the upper mids and treble. But, I was surprised to see Gem2 actually seems to offer smoother midrange directivity and sound power than Salon2 per the equivalent-methodology Harman measurements. (There are higher-rez scans of Salon2 but not Gem2.)
See simplified
Spinorama below, with just listening window, sound power, and directivity index. I'm not at all sure why that would be the case given the identical mid and tweeter, and baffle geometry differences that intuitively at least highly favor Salon2 (sculpted vs. flat with a step on either side).
In any event, Gem2s with appropriate bass support and room correction both sounds really nice in the sweet spot and is the best background music system I've yet encountered. You don't get the palpability of a well-spec'ed-and-tuned immersive system, but for 2 channel it's hard to beat. Never had an opportunity to compare directly with Salon2, alas. However, it was favorable experiences listening to Salon2 that led me to look at Gem2 in the first place.
