Is the Hidizs MP145 PRO Worth $169?
Mark11
I’ve been planning to try a planar IEM myself to see how it really performs compared to a single DD. I’m also considering the LETSHURE S12 Ultra — curious how it stacks up in clarity, bass control, and soundstage. Which one would you recommend me?
If you’re specifically trying planar for the first time, both are solid picks but they go in slightly different directions.
Thank you for the comment and the help
I am currently sing Hidizs MP145 4.4mm version and they are excellent, I have never heard of or used LETSHURE S12 Ultra.
I have the Hidizs MP145 Pro backed and they were delivered 2,5 weeks ago.
For me they are "to spicy" - had to use the red "bass" filters and the bassheavy eartips to tame the treble and bring voices a bit forward. But voices keep sounding a bit wired and to much in the background.
usually I hear with DCA Aeon2 Noire and Letshour S12 (the original version) so I'm used to very detailed and bright sound - but this is to much for my ears.
I would try the S12 Ultra or the newer Astralis (but different driver type).
Also the Kiwi Ears Aether and 7Hz x Crinacle Divine are on my "watchlist"
If you like to try out planar IEM than I would recommend the Artti T10 (OG - not the newer pro) - very similar to the S12, same company, but cheaper plastic shell
