Is the FiiO BTR 11 my only choice under 20€ as LDAC BT adapter?
kazuviking
Bought a CVJ Neko(sucker for 3D CNC) and in search for a BT adapter that is cheap but not garbage. I have a glazata bt adapter but that is soldered to a 16 core cable as the 3.5mm connector broke early on and have random button press issue since i got it.
So i'm searching for a BT" brick"/neckband/earhook adapter that supports LDAC(fuck you samsung for not supporting aptX A/HD/LL) under 20€. The FiiO BTR11 is constantly under 20€ on ali and it doesn't look bad. Found countless neckband asnd earhook adapters with LDAC support but NONE of them comes with a slightly protruding 2 pin connector that would fit the Neko perfectly under 20€. KZ and TRN have a bunch of adapters that would fit BUT it starts at 30€ which is outside of my strict budget.
If you have any feel free to share.
TiA.
