I m a French that made 5year engeenering school in electronics mechanics and informatics. I learned the theory of fft and shanon theorem and discret method of interpolation. We had to calculate the transfer function and we learned how to make filters of different orders and to calculate the cut off frequency etc. Also we learned the difference of technology beween transistor npn pnp polarized jfet mosfet bipolar etc. Also the differents circuits or regulations made with transistors. Also the different uses and shema of opa. How to calculate and design the gain or the filter etc. Now i m developper in assembler language and c. I made a stage at the end of my school where i designed power for led on a light for doctor in surgery blocks. I designed the interface to dim the light with a micro controller. I choose the ir captor and then wrote the agorithm so that the light remain constant wherever the surgery is under the light. (More light where he doesn't stand under). I could adjust 8 modules individually. Light was dimmed by adjusting the pwm ratio. The pwm signal from the micro controller was driving a i regulator i had to design and i made one with transistror technic. Because leds are driven with constant i the light was adjusted by dimming with the pwm on the microcontroller. Each module had a micro controller and where slaves of a master microcontroller. I made code for both and designed prototypes for all the board and alims etc.What do you do professionally if I may ask?
No my work is far less interesting.
