boxerfan88
- Joined
- Oct 23, 2018
- Messages
- 1,335
- Likes
- 1,630
That’ll be nice.Maybe we need to use 50 shades of grey?
If that is really the case all one needs is 2 tiers .. for instance green and red... or 'transparent' and 'may not be transparent'There is only one certainty: if SINAD is better that 115 dB, it guarantees transparency.
You guys must think a bunch of idiots read my reviews.
There is a contradiction again there, if the readers are experienced they don't need such arbitrary ranking classes and if not they can be influenced by such in a wrong way as it is been seen so many times in discussions. One approach would be to make just a summarizing table with the main measured values from SINAD over IMD to channel imbalance and next to them some approximate limits under which a deviation might be audible and if for some not feasible a min/max range from previously tested devices but without a qualitative comment. As its now it seems that some inexperienced readers seem to concentrate on high SINAD devices which often have other issues which might be more problematic and audible then a lower SINAD device which doesn't have such.Once more, the categorization, as shown in colors, is to get people to think about four broad categories of ratings here, rather than individual values.
Constant complaining? That's a mischaracterization.Then quit saying people are confused when one device has a SINAD of 99 and another 100 because they are two different colors. You are solving nothing with your suggestions and constant complaining across topics.
I don’t believe there are any conflicts or inconsistencies in my comment, so it seems that either you’re not interpreting it correctly, or I’m not expressing it clearly.Your belief is in conflict with your own argument as I explained to @thewas. Once more, the categorization, as shown in colors, is to get people to think about four broad categories of ratings here, rather than individual values. It was a solution that was created based on consensus from me and membership. You have made no logical or rational argument to change it, on top of it being totally inconsistent with your own position.
Adding colors
www.audiosciencereview.com
Thanks, I understand the reasoning behind adding them. I’m simply suggesting that they might also contribute to the misinterpretations we’ve observed, for the reasons I outlined in my previous comment.![]()
SINAD table colour brackets
As a slight introduction: I'm a new member. I've been following along every review since the Google Pixel adapters which, looking back, was a only on a ti-ny SINAD list! Thanks @amir for all your hard work. Before ASR, I had little to no proper foundation on what DAC to buy other then pricing...www.audiosciencereview.com
JSmith
All good mate, was just pointing out the thread from 6 years ago where it was also discussed. If you look closely you can even see a post from @amirm where he expressed a possibility of having to defend the categories and a desire not to... but in the end everyone decided what was proposed was good.Thanks, I understand the reasoning behind adding them. I’m simply suggesting that they might also contribute to the misinterpretations we’ve observed, for the reasons I outlined in my previous comment.
JSmith
So this one was 89.4 & 89.8, midpoint between the two is 89.6.Example the SINAD 90 devices straddling both POOR & FAIR categories.
89.6 & 89.9 round up to 90, but are technically still in the 89.* grouping when looking at the more exact data in each review.
The others in orange that start at SINAD 90 had figures that started in the 90's, thus are in the other category.
JSmith
So what's left?
You hear noise at YOUR system>no,good.
Your hear distortion>no,good.
Blacker black!You missed an option, actually the most common one:
You hear no noise at your system, but you buy an upgrade and you hear the noise floor is lowered.
Blacker black!
Yes, this is exactly what I've been saying as well! Clarification for all those people that don't fully understand all the measurements while not affecting those that do understand it, this won't hurt in any way. Because again, people quite obviously misunderstand that SINAD ranking list so why not help them a bit? This in the end will also help ASR as a whole so it's really a win-win situationGrading products by tiers influences how people perceive them. Adding colors to these tiers amplifies this effect, especially when the colors evoke emotional responses or are associated with good (green) and bad (red). This kind of framing and introducing of interpretation bias doesn’t align well with the principles of science, where data should be presented objectively.
With this in mind, I suggested that the pushback on the SINAD value might stem from how powerful the chart is due to these interpretive mechanics.
I then proposed that the effect and potential misinterpretation could be reduced by making the chart more neutral -perhaps removing the colors and showing only the values. Additionally, I recalled the use of "strict" and "lenient" terms to describe two thresholds, where "strict" represents absolutely inaudible and "lenient" represents inaudible in most real-world scenarios. (I haven’t verified if these descriptors are completely accurate, but that’s how I remember it. Feel free to correct me if I’m mistaken.)
These descriptions could be incorporated into the chart, perhaps as dividers or dashed lines, adding clarity and usability while grounding it in science. This approach could also help educate users in a meaningful way.
None more black. I don't know, I've never really had an issue with audible noise in my system, so not sure I would notice a lower noise floor. I also don't listen to vinyl, so maybe that's where all this talk of lowered noise floor and blacker backgrounds stems from.That and "darker background".
I have never figured out what "dark background" really means... relating to equipment changes.
Yes, this is exactly what I've been saying as well! Clarification for all those people that don't fully understand all the measurements while not affecting those that do understand it, this won't hurt in any way. Because again, people quite obviously misunderstand that SINAD ranking list so why not help them a bit? This in the end will also help ASR as a whole so it's really a win-win situation![]()
Yeah it's just that he seems so very reluctant which I don't understand why. But yeah, it's been said enough at least from me by now.This has all been said before; there is no need to beat a dead horse. @Amir is aware - it's up to him, but more importantly, it is up to us (speaking for myself also) to educate ourselves.
