So the same thing for Sealed Subs?
To a great degree yes, if the design is well done both ported and sealed subs can work well "for music" which I assume was what you were referring to? There are poor designs in both areas, tho....
I shall now speculate, COULD it be larger drivers which produce lower frequencies with more effeciency and SPL are harder to integrate and can somewhat 'colour' the audio - if not integrated properly, placement, room eq/modes etc
I would explain away most end user shootouts as unintentional positional EQ (i.e. size of the boxes and positions of the driver) or obvious differences in the raw output and FR of the units being compared.
They still sound different. You see people finding the Arendal and Monoprice subwoofers sounding drier, different to SVS this has been mentioned many times on AVSF who have had both in same room. RELs faster than SVS. Jim Wilson with 20+ years experience with subwoofers found the JL E112 sounding better with music than SVS SB13U etc. which caused almost forum meltdown cause SVS fanboys couldn`t take that, hah. Lots of examples. It would be foolish to only look numbers, but each to their own.
Sealed subs are smaller than ported ones, that's the main benefit.
Ported subs have very high group delay around their tuning frequency, so it's best for them to be tuned under 20hz. There's no evidence that there are any audible problems with large, well-engineered ported subs with tuning frequencies below 20hz(eg: JTR). It is potentially possible that smaller ones with 20-30hz tuning frequency could have audible issues. Though granted it is unlikely as discussed on the Audioholics page.
Not sure what the tuning frequency of the FV25 is, but I hear 0 speed difference between it and the sealed RS2. My general view is that ported usually gives better performance for the money, though there's obviously still a market for sealed subs.
... First, I bought into their marketing "There are subwoofers and then there is REL" which is a good line, btw. ...
Hmm. According to some quick measurements I took, the new SVS (with DSP) has much lower delay than the REL (without).A sub with dsp will have higher latency than a diy sub with no filters at all.
The REL has filters too these are analog.Hmm. According to some quick measurements I took, the new SVS (with DSP) has much lower delay than the REL (without).
Yes, and they are terrible in comparison.The REL has filters too these are analog.
The smallest SVS seems to be: 13.0" (W) x 13.5" (H) x 14.8" (D) | 12" woofer
Apart from physical constraints (SVS is just too large), does the pairing of subwoofer size matter when talking about "seamless musicality"? For example, is it better to pair the Focal's 6.5" speaker size with an 8" woofer? Or should a 12" woofer pair just as well (or better), even though it is a massive jump in speaker surface area? To be clear: context is music only (e.g, bass, piano, drums), not HT movie LFE effects.
So, then it sounds like if someone (gasp) isn't going to do room correction/measurement and (double gasp) doesn't care as much about output and extension then the REL subs are a good option.
