If you have a look at a loudspeaker with eq you need to have a look at the di curves. With a loudspeaker where the direct sound is equalized to a flat line, the sound power fr and early reflections fr is 100% correlated to the sound power di and early reflection di.The DI are just a small part of the spinorama, also the Harman score equation doesn't take into consideration the DI curves at all as their correlation was smaller than on other variables, see AES 6190 paper.
Both curves the early reflections and sound power are used to estimate the in room response. If I remember correctly, all three curves are highly relevant to calculate the preference score with the multiple regression model.
The listening window fr and the fr of the early reflections is imho the important part to extract form the horizontal plane if this is fine than all other messiness is as important as the messiness by changing the vertical angle, since it only contributes significantly to the sound power fr. These two informations (listening window fr and early reflection fr) are also exactly what the preference score is using.I beg to disagree there though, look at the normalised directivity plots I posted above, this mess cannot be corrected by EQ.
Yes but (with an equalized loudspeaker) it is as of today a good enough "smearing" to be utilized for calculation of the preference score. It has yet to be proven that the extra information can improve the preference score.I see it rather the other way around, the DI can smear/hide many problems and lead to wrong conclusions.
