Symphoniac
- Joined
- Jan 5, 2024
- Messages
- 88
- Likes
- 44
I noticed that (sometimes) when I jump to a different point in a track, my speakers make a popping noise. Seems to happen when I'm streaming a digital source, such as playing Tidal or FLAC files via Roon. For example, let's say I'm using Roon to play a song and the 'pointer' in the song progress bar is at the 1:20 mark. If I drag the pointer and drop it to a different point, let's say 0:35, then the song will pause for a split second, make a popping noise, and resume playback. This doesn't happen every single time I scan through a track (probably roughly 50% of the time), and it is a bit alarming when the volume happens to be set to a higher level, which naturally causes the popping sound to also be loud. I worry that this may potentially damage my speakers, so I have refrained from doing this, or make sure to lower the volume before scanning within a track.
My question is: is this normal behavior or does it indicate something wrong with the playback mechanism (my digital streamer/pre-amp)?
