is my room small?
amogus
Hi, I'm currently using edifier mr4 with some eq, and it sounds pretty nice. But I wanted some more bass extension, so I'm looking to buy a pair of 305p mk2. But, my room is 2.7m wide and 2.4m high, and i don't know if my room is small. Will 305p (5 inches) fit my room? (not acoustic treatmented tho)
You don't give width and depth, but if it is 2.7 x 2.7 x 2.4 then it would be considered small. The 305 would probably be fine in it. You might consider a 306 or 308. But the 305 likely would be enough. It has more bass extension than most 5 inch two way speakers. I've some of the mk 1 305s I've used in spare bedroom about that size. It is fine.
