Get rid of your Kef q300 if you want to be able to play really loud. They can't handle it. Go full PA if you really want to drive your neighbors crazy and yourself deaf.
A compromise, home hifi speakers like Heco Aurora 1000 with 91dB sensitivity and Power Handling (RMS/MAX): 230 / 380 watts will go a long way.
Not crazy loud like PA insane high SPL, but you can play really loud with them. Plus they sound good, which is a nice side effect.
A sufficiently powerful amplifier you can fix later. Good, cheap amp watts are now on tap.
If for some reason you should insist on having bookshelf speakers (choose ones with the highest power handling you can find) then add multiple subwoofer. Of course powerful ones. As physically large subwoofer boxes with as large subwoofer speakers driver you can fit in your home and what your wallet can handle.
By the way; better yet, these subwoofers plus the Heco Aurora 1000.
The reasoning above is based on the premise that you want to play at
REALLY high volume.
Edit:
I missed it, TS has a sub: Svs sb2000 subwoofer.
Add another Svs sb2000.
@WideEyedToad what is high volume for you? Can you quantify it? Until then we can talk past each other. High for you low for me or vice versa, you know.
