A better job in what way?Because I know the Yamaha is multi-purpose and the DAC in it is very good, but not superior. I thought that ab independent DAC would do a better job by design.
That was a top result when I searched but wasn't an exact match, don't know about the "model 9" someone else mentions.I figured he was talking about the Polk LS/9, I was wrong. I'll delete my post
No, probably not.So even though all the Behringer does is pass on the signal it degrades it?
There are probably DACs that will deliver 10-100x less noise and distortion than the Yamaha. Intuitively this sounds like you should be hearing massive improvements. However, DACs were already good by the late 1980s and they were really excellent by the mid-90s and beyond, in practical usage. Newer DACs have such good performance that it should be impossible, not just unlikely to hear any artifacts. But most decent DACs, even old ones, have performance that is totally transparent in normal usage. You almost definitely won't hear improvements by getting a better DAC, but you might achieve a little more peace of mind.As for the Yamaha, yeah I figured the DAC was good but could be improved upon.
Aside from price, I wouldn’t even know where to begin in choosing one.
No, it doesn't - I suspect @Karmacoma had not noticed you were digital out of the Behringer.So even though all the Behringer does is pass on the signal it degrades it?
We don't have measurements, but:Because I know the Yamaha is multi-purpose and the DAC in it is very good, but not superior. I thought that ab independent DAC would do a better job by design.
No, it's just that I extrapolated the quality of his 2006 behringer soundcard based on other behringer gear measured on ASR. I expect jitter, noise and also maybe too that the conversion is not bit perfect, I find that plausible even if it's used as a USB/toslink converter. Am I wrong to find that plausible?No, it doesn't - I suspect @Karmacoma had not noticed you were digital out of the Behringer.
It's plausible but in terms of audibility still a real stretch IMO since there's no D/A step. I remember seeing a blind A/b/x test of cheap interface DACs of this era (contemporaneous) and the conclusion was that they were transparent across the board, even the cheap ones. I mean, have we ever seen a DAC with jitter bad enough to be easily audible in one of Amirs tests?No, it's just that I extrapolated the quality of his 2006 behringer soundcard based on other behringer gear measured on ASR. I expect jitter, noise and also maybe too that the conversion is not bit perfect, I find that plausible even if it's used as a USB/toslink converter. Am I wrong to find that plausible?
And why do you think this is unlikely? Do you have evidence to support your claim?Hi, welcome to ASR.
We don't have measurements for your interface, however it is very, very unlikely that a 2006 USB interface from Behringer doesn't degrade your sound, even if you use it as a USB/optical converter.
Hi all,
I'm trying to figure out if a DAC would noticeably improve the fidelity of my system.
This is my current setup:
PC running Win 10 and Foobar -> USB Behringer UCA 202 -> Optical out to Yamaha RX-A740 -> Classic full size Polk 9 speakers (from the 1980s).
Do you have evidence to the contrary? And, if so why not share it?And why do you think this is unlikely? Do you have evidence to support your claim?
Not the sound, it was incorrect, but the signal yes, I extrapolated it basing it on the usually pretty poor quality of measurements of behringer digital gear, and here it's a soundcard from 2006. I actually said it would probably not be audible but it's certainly not good. Whatever the creator of the thread should invest all his money in a set of new loudspeakers anyway.And why do you think this is unlikely? Do you have evidence to support your claim?
Probably. - And on Toslink, noise just isn't a thing.Am I wrong to find that plausible?
He made the claim. We are waiting for his supporting evidence.Do you have evidence to the contrary? And, if so why not share it?
