SuicideSquid
- Joined
- Jan 20, 2022
- Messages
- 1,118
- Likes
- 3,090
Tubes are great for guitar amplifiers, microphone preamps, etc., where you're intentionally trying to colour the sound for musical effect.Hi everyone,
As the title suggests, I recently came across several YouTube videos discussing this audio paradigm.
I’ve just purchased the Meze Empyrean II headphones along with the JDS Labs DAC/amp, and the combination is fantastic. I followed recommendations from this forum to make my choice, but now I’m starting to wonder—should I aim for something more, or do all amps sound similar?
When you're listening back to a finished recording, that work has already been done by the musicians, producers, and recording engineer. If you pile more tubes on top of that, you're just colouring the sound further.
Think of it like camera lenses for a film. A director may choose a yellow gel to tint the image he or she is capturing in a particular scene to set a particular mood. But when you watch it back on your TV, you want your TV to be neutrally-calibrated, so that yellow-tinted scene shows up properly yellow, and a blue-tinted scene shows up properly blue, and a natural daylight scene shows colours naturally, as director intended. No one puts a piece of amber-tinted glass in front of his TV and then says the picture is better now because it's "warmer". That would be insane.
Tube amps are like that piece of glass. They block you from accurately hearing what the artist and recording engineer intended you to hear. Tube amps are much more likely to add audible distortion, roll off high frequencies early, and have a higher noise floor than solid state amps that are audibly transparent, 'tinting the glass' when it should be transparent.
As to the "do all amps sound the same" question - yes, with a big caveat. All properly-engineered amplifiers that are not being driven to clipping/distortion will sound the same. In fact, if you're a really good engineer and you're working with low-powered devices (like headphones) you can even get a tube amp to sound transparent. If you push amps out of spec, or if you have a poorly-designed amp (both of which are usually the case with tube amps), you will start to hear audible differences between different amplifiers.
There are many options for completely transparent headphone amplifiers that will not clip or distort until you're well past the level that will damage your hearing and your headphones, for only a few hundred dollars these days.
