Is it possible that the products sent by the company to ASR for testing are specially selected high-quality units?
Headphones can have significant unit variation, so even without the manufacturer making a special selection test units will often differ. For example, there was talk about a silent revision of the Sennheiser HD560S, which supposedly reduced some treble sharpness. The measurements that started this showed a clear improvement. Yet measurements "guru" oratory1990 states that he has measured multiple units from before and after that speculated change, and that he saw nothing beyond unit variation.
As far as Amir tests devices sent in by regular buyers it should be safe.
As for devices that come directly from the manufacturer: If you were a manufacturer and wanted to send a device to Amir—knowing the impact his tests would have in the small world of audio enthusiasts—would you just take any random device off the production line without testing it yourself before shipping it? Definitely… not. The risk is far too great that a product that cost hundreds of thousands to develop would effectively be dead before it even hit the market, simply because you happened to catch a lemon from the current production run.
But I don’t believe in the “building a special unit for amir” theory,
As far as I can tell, Amir always says how he obtained the unit.
If you are paranoid, you can use that to adjust your skepticism level.
Don't bother ASR about it, though, unless you have substantial reason to.
When I was in the industry this was an acknowledged tactic but we never did it, we simply checked units going to reviewers make sure they weren't defective.
In general there isn't enough inter sample variation in these products to change the outcome of a review if you choose the best one from the line and send it. Maybe a percent or two, probably less.
And as others have mentioned the risk of getting caught is high. Many reviewers could make the same measurements. So it's not worth risking your brand over a small performance bump in one of those reviews.
I think the place to watch out for this practice would be speaker or headphone reviews by reviewers who don't make measurements. The risk of the manufacturer getting caught is much lower that way.
I don't think a manufacturer would send a premium sample just make sure it is a working sample without any defects. I think if a manufacturer knows it wouldn't perform well or has different design criteria like a speaker with elevated highs or bass, etc. Because they find that sells better in the showroom. They just wouldn't send in a sample. Amir does accept samples from manufacturers and dealers and states where he received it. I sent him a speaker but he hasn't teste it yet. He also states if his company carries the product. I don't think that has impact on his testing.
Consumer Reports (CR) Magazine anonymously purchases the products it test and reports on. They have a highly regarded automotive test track that provides different road conditions on different parts of it in order to see how cars handle them. Carmakers rent time on this track to test their new designs. The anonymity of CR's purchases guarantees that they get stock items, not specially checked and upgraded ones. (no affiliation with CR beyond subscriber).
Are the different reviewers you mentioned using products that they purchased themselves, or products sent in by consumers?
You started the thread with accusations and suspicions. Why not you do the legwork of showing us the evidence that makes you suspicious?
有证据就提出来给大家看,不需要在那疑神疑鬼的。
that’s my point. now definite what “defective” means. Shouldn’t be just the “power lamp goes on” test.
Defective in the sense of... doesn't turn on, a screw is loose, etc. Something that should have been caught in QA but wasn't, something that would prevent the reviewer from completing a review. As you note, nobody wants to send a lemon by accident.
Every product will have a different threshold for what counts as defective, but as long as you would accept a return from a customer over any defect you catch at this stage, I would say it's fair game. You're just double-checking your QA to not waste the reviewer's time, in a sense.
What OP is asking about is testing multiple units to find a lucky one that performs better than average. Opening the box and plugging in a unit to make sure everything is in place and functional, I would say is a horse of a different color.
Exactly. It's just a sensible precaution to check an item before it goes out for review. The consequences of a faulty item getting to a customer is a disgruntled customer. The consequences of a faulty review item could kill the product.
S.
As is well known, due to quality control issues, each unit of the same model may vary in quality. Is it possible that the company selects the best-quality unit for testing, or even uses better production methods and materials? If so, that would mean the consumer version we buy may differ in quality.
Some of the tested products yielded lower measurements than others.
Could one conclude that the manufacturers deliberately designed them to receive unfavorable ratings?
You see, one need only reverse your proposition to grasp its true value ;)
Why would a manufacturer go through the trouble of either a) making a special unit that out-performs production, or b) finding the 1 unit in 1000 that outperforms everything else in the batch. Especially because Amir isn't paid to do this, sending misleading units would only serve to tarnish a brand's reputation. Conceivably, if it were a sponsored review you could possibly get away with it, but again, there is just too much risk. As someone else also pointed out, the devices we are talking about can be made with off-the-shelf consumer parts, so you are not likely to see large unit to unit fluctuations.
This is why subjective reviews are so important. Since they are based on bias, expectations, and myriad other influences, the enhanced performance of a golden sample would have no bearing on the findings of the review. So, really, when you think about it, subjective reviews are more reliable than objective ones.
