Is it possible that the products sent by the company to ASR for testing are specially selected high-quality units?
Huang1997
As is well known, due to quality control issues, each unit of the same model may vary in quality. Is it possible that the company selects the best-quality unit for testing, or even uses better production methods and materials? If so, that would mean the consumer version we buy may differ in quality.
Amir tests products from companies, private members and retail models.
Any company trying to do this would be easily caught out and there is zero evidence of "golden samples" in the majority of cases.
JSmith
For most devices, that idea is complete nonsense.
First of all, a vast number of the devices tested by Amir and other members are standard retail units over which the manufacturer has no control.
Why would a manufacturer go to the trouble of developing a special unit for testing purposes—only to fail to incorporate those superior performance characteristics into actual production?
Using different components or circuitry would be spotted very quickly, given that photos of the internal components are posted for most devices.
The risk of a manufacturer being exposed is extremely high these days, as affordable, high-quality measurement equipment is now available to everyone—even for as little as €100–300.
Tests conducted by users on ASR, DIY Audio, and other forums typically show only minor, negligible deviations within the range of measurement tolerance.
Furthermore, we have many highly technically knowledgeable users who would certainly voice their suspicions if anything seemed amiss.
I can speak to this from personal experience. For years, we tested high-end cameras and lenses—most of which were provided by the manufacturers—but we also regularly cross-checked them against units purchased through standard retail channels.
There wasn't a single instance where we suspected a manufacturer of sending us a superior or specially selected unit. Quite the opposite: on several occasions, we actually had to request additional test samples because the unit we had tested performed too poorly.
Conceivably a product might have high unit-to-unit variations in the course of normal production. Possibly the result of poor quality control in production, possibly the result of inevitable upstream component variability. So the manufacturer might test a number of their units and choose the best to sent for testing.
Of course it's possible. It can even be done unintentionally. That is why it's important that Amir isn't the only one testing products. Unit-to-unit variation can only be tested by the community as a whole.
I think this is highly unlikely.
Firstly, components these days are remarkably consistent. x% resistors or capacitors are very close to ideal, and active devices likewise. It's just possible that one finished unit measures that tad better than the worse, but either will be WELL withing normal tolerances.
Secondly, even in the 'bad old days' of valve-based equipment, when tolerances were much wider, as soon as feedback became the norm in the 1930s there was much less variation between samples.
Design decisions make a far greater difference to performance than sample variation, so whatever is tested is far more likely to be representative than a selected sample.
S.
JSmith
S.
in the smartphone industry, there is this phenomenon: for the same model, the mobile SoCs and memory chips vary in quality at the production level due to quality control. Manufacturers send review units to the media that use better‑binned SoCs and memory, or even higher‑frequency memory, resulting in overall higher performance for those review units. A specific example is the review outlet Geekerwan, which conducted a test where they deliberately bought retail phones and compared them with the press units sent by the companies. They found that most retail phones showed significantly large performance differences compared to the company‑supplied review units
Rather different to audio equipment where the technical requirements are pretty trivial compared to high UHF or microwave RF. Mobile 'phones are computers, DACs and amplifiers, whilst including some computing, are still pretty basic in performannce requirements.
S.
You can check out recent reviews by @NTTY. He tested some DACs which were previously tested by @amirm and - as far as I know - NTTY simply bought retail units for that. The tests show miniscule differences of fractions of a dB for important metrics. The differences can easily be explained by the different analyzers being used (APx555 vs Cosmos ADC) and even if they were still present when tested with the same analyzer, they would not be relevant to the performance of the devices.
The differences between individual units are also way smaller in audio devices than in smartphone SoCs. Can't really compare these categories: One uses bleeding edge manfucaturing nodes at TSMC or Samsung and the chips are at the very edge of what is currently possible to mass manufacture. The other uses bog standard components you can order at DigiKey.
In addition, there were multiple cases where Amir discovered design flaws or firmware bugs in the tested devices and worked with the manufacturer to confirm them. Doesn't seem likely that manufacturers would willingly send him devices with those flaws if they already supposedly went out of their way to select Gloden Samples (TM). So as it stands right now, I have seen absolutely no evidence for any cherry picked units arriving for testing. It's not impossible, but there is simply zero evidence for it.
S.
My example wasn’t about phone audio performance—it was about the performance differences in CPU and GPU testing on the SoC
Many current mobile OSes actually detect benchmark binaries and lift all the power limits so the phone goes faster when running them.
It’s possible that there wasn’t actually per unit variation for this thing you quoted and the actual effect was due to them using different binaries than the exact blessed benchmarks sites were told to use for review models hence the power limit lift did not activate.
It’s not about the gap between official lab tests and consumer tests of retail units, but rather the gap between official press samples and retail units when reviewers use the exact same testing methodology. Moreover, it’s not about the power consumption ceiling—the key lies in the efficiency curve (performance per watt), not in comparing performance at the highest power draw
Some discussions are so far from the non-paranoid consideration of audio science and music reproduction, and are so centered and focused on extremely online notional disputatiousness, that I have zero interest in where it goes.
@Huang1997
You have every right to voice your suspicions. But there are also clear evidence that show different reviewers arriving at the same conclusions in comparison to Amir's reviews, for example, RandomEar's reply above.
I understand your reference to the Chinese mobile phone industry and probably to the silencing of 极客湾 / Geekerwan after his expose of performance differences in media units for reviewers vs retail units a few months ago. But as far as the forumers can tell here, no such thing is happening.
@Huang1997
Are the different reviewers you mentioned using products that they purchased themselves, or products sent in by consumers?
