Is it okay if I just use a portion or half of the ground wires soldered to the XLR microphone cable?
Dipypang
Is it okay if I just use a portion or half of the ground wires soldered to the XLR microphone cable because the ground wires is so thick and hard to solder all of them…
You only need one ground wire, which should be the shield.
If you have room inside the shell you can solder multiple grounds (including the shield) to a thinner wire for soldering to the terminal, and then put heat-shrink over where the wires are joined.
Yes, it is fine to do that.
Regards,
Wayne A. Pflughaupt
Regards,
Wayne A. Pflughaupt
Thank you! Have a nice day~
