Has anyone else been looking at tonal differences between upmixing Stereo to 5.1 by Dolby Surround and DTS Neural-X?
I always found Neural-X more distant or muffled. Simply playing with center level, center spread or treble did not work out. Finally, I measured it.
Setup: SynRTA with noise signal for center only, measured the frequency response with Neural-X, set it as reference and measured again with Dolby Surround. I got the following curve:
I then created two Dirac-Live targets adding a) the difference and b) half the difference to my usual simple sloped target curve. For simplicity, I only considered the correction above 1 kHz. The L/R ratio was flat with a below 1dB difference.
While the full correction was somehow too much (difficult to say of what), the half correction was surprisingly pleasant.
I wonder if the measured difference and dullness of the Neural-X upmixer is systematic or something particular to the Onkyo?
