The KEF R3 speakers are rear-ported, meaning their bass output can be amplified by proximity to walls due to boundary reinforcement. At 50 cm, you’re likely getting some bass boost, but it’s not as extreme as if they were closer (e.g., 10–20 cm). If the bass sounds boomy, muddy, or overpowering in your room, closing the port with the provided foam bungs can help tighten the low-end response.
When to Close the Port:
- Close it if you notice excessive bass or a lack of clarity in the midrange, which can happen if the room reinforces low frequencies too much.
- Keep it open if the bass feels balanced and well-integrated with the rest of the sound, as closing the port reduces bass output and may make the sound leaner than intended.
I personally would keep it open, but it's up to you. The main thing is to understand why you should do or not do something and trust your ears and measurements, and not someone else's advice (not from me though, you should trust my advice. Kidding
