Is coax 75ohm stupid legacy for home use?
Answering OP's original question...
Sometimes for experimental purposes (or for the quick capture of a DAT tape or something), I'll grab a video cable out of the "cable hell" box to just rig something together. There is a 50-50 chance that it will work. I've had runs that are less than 1 meter that just wouldn't produce ANY audio (even at the relatively low speed 44kHz / 16 bit), but are perfectly reliable and work fine for composite video or analog audio. I also test devices with non-standard AES/EBU interconnections at work and I find that sometimes they can be quite sensitive to slew and noise.
Using shielded 75ohm cable from source to destination is an excellent way to avoid future headache and debug. Skimping to save money or time now will cost you much more of both later. Whether or not you bundle the cables into a (not-so-easy-to-source) multipin connector or not doesn't functionally matter as long as your cabling and mating connectors conform.
Cables periodically fail when you least expect them to so I personally prefer using common & easily-sourced interfaces and connector types so I can swap them out on the fly, but that's just me and my personal need to debug efficiently and methodically.
Cat snake cables are even available off the shelf, terminated in Neutrik etherCON connectors or copies thereof (basically an RJ45 with gold-plated contacts shoved into an XLR sleeve).
VORSCHAUBILD - etherCON Cable + Chassis - 202307
I use these in a commercial environment where we cycle them thousands of times. They work wonderfully with high reliability.
Do you already have wiring, in-wall or not? If you do, all you need are the appropriate adapter/cables.
I have enough to make something complete, but im gonna make a second buy. Im gonna go through all info here, and make a list for parts. Cat8 multipair ill get some meters and see if I can work with for sure. Whatever fits and works.
If I only used standard parts this could be done in a couple of hours, 1.5 y ago. I have a "9.5 4way D-style steel front. Could just get a standard steel case for it, and filled it up. I just thought quality sucked. Holes werent even aligned. I wanted something better for my RME boxes. My post: Is coax obsolete. Thats frustration over that water-hose cable tech I thought Id have to use for my creation. I use RME hardware and software in my home setup, so that what its for. Now I have used this forum post to distil my project. Lots of great ideas here, but though some/all of them are very technically sound. They may not be practical for me.
Fancy wood + cool contacts + smart and simple electrical design + practical use + having a good time doing it = kicka** breakout box
@Kal Rubinson Industry insider. My investment in traditional wood veneering amounts to twin AHB2 and a nice set of speakers. What do you think about that? Its never meant to pay off. The way i am working this it will pay for a cup of coffe in 50 years, maybe. :D Another 50 for a Big Mac menu. Would be nice to make up for some materials, but its not a commercial project like the myriads you can find on FB and Instagram. I used to spell Johnsson with capital H so Im just making up for lost time. Beauty lost and found. Sure a New Yorker and grownup man could understand ;) :D
Stereophile, thats where I first heard about RME. A PCI card solution. A bit premature for the internet, digital audio revolution. Interesting none the less. You would be a fool not to see some possibilities out of that article. When they launched ADI2-DAC fs, desicion was a no-brainer.
From 2002
A ways back.
I had a twin isdn 64+64kbps in those days. It was actually fast for rural Norway at that time. I liked this soundcard tech, but a bit thick for playing mp3´s perhaps.
I’m not sure if you realized, but did you notice the name all the way at the end of that 2002 Stereophile measurements page?
A ways back.
I bet its a lifetime for some ASR users :)
So you see im a RME fan. I first had ADI2DAC and digifaceUSB. Then I upgraded to a UCXII/ADI2PRO combo. As a preamp its just insane power, ive never counted how many EQ´s I can put in a chain etc. Via TMfx I can setup routing for any situation. Digital process is transparent to the user, and so on. The icing on the cake is that enthusiast like me can actually afford it, DIYers dream tools. It takes some dedication though, to get the most of it, but its all well documented with thick manuals and videos. Software and drivers are super stable, far better than say NVidia consumer stuff. Ive had NV since TNT2.
You should call MC at RME, maybe he can lend you a couple. Do an article, like a reviwal of that 20y+ piece. Audiophiles can be a conservatitve crowd, but I bet some of your readers would really enjoy it.
In the end It will just have to be tried out I guess. I have a cable hell box to, so. Ive been thinking of ways to stress test. I have RME bitest, it can give me an idea of dont-almost-do work. It would be interesting to try it out at a lower level, maybe even with a cheap oscilloscope. I dont know about precision of those or how to operate it, If i can set trigger points, my idea was to pick up and render disturbance and interference in real time. I have DDS signal generator, ocilloscope and laboratory PSU on my bucket list :D
I messed up my head about those connectors. Im gonna try out, suggested here shielded CAT8 multipair. I have some experience with Lemo, tight to solder but really good quality. If it doesnt work Ill redo it.
Conform, how precisely?
This makes sense, and certainely pricing for parts. ,but with this project estehtics is certainely a parameter. With that in mind a standard DB-9 might not just fit. Its ugly and reminds me of clumsy VGA monitors. Then again I could buy 50 of them and my wallet wouldn´t notice. They are a euro apiece. Ethercons and better Neutrics are up to €20. A set of 9-pin Lemo is like :D €60 or something. For a single project I can stretch it.
"Is coax 75ohm stupid legacy for home use?"
uh... the infinite millimeter of copper is 75ohms
why is that bold omg what have i done...
a circuit of 18AWG copper, it is infinity long, presents 75 ohms of resistance.
what does that have to do with anything other than it's 18awg copper conductor?
surge impedance just the cylinder of copper, you don't have to actually like energize the loop... that's what the cable company does.. like all that solid core copper is a mm in diameter and they send a bunch of megahertz down like a hall of mirrors, so it's important to know, 75 ohms for the whole friggin network. is like a saturation point, so like your network speed in a way is relative to the characteristic impedance, as far as the whole radio transmission line aspect is concerned.. it's overkill for home use like idk if it's stupid it makes perfect sense for video, i think audio it is kind of dum we should be using differential RCA i/o by now. twisted pairs for short runs would be better if everything was actually differential (HDMI entered the chat)
Kind of fragmented. You could just post the links: SHURE:Transmission lines part I
In the Shure paper, it should be:
a] Radio Frequency Characteristic Impedance
b] that short form formula only works at frequencies well above 100 kilohertz.
Did not read much of this thread and have a mile of the that cable in my walls. Found that it and this can solve some WiFi issues for not much $$$.
Except that usually RF stuff is 50R impedance…
From their site
"Wi-Fi over coax delivers a Wi-Fi signal by sending a signal along the conductor inside coaxial cabling, using the cable's shielding to reduce interference. Wi-Fi over coax can use 50 Ohm cabling, or 75 Ohm cabling with impedance converters, as Coaxifi kits do. Our splitters are custom-tuned to Wi-Fi frequencies, with far lower insertion loss than typical TV splitters (-0.5 dB versus -7 dB for a 4-way splitter, preserving 89% of your router's output power)."
Do you use these? Reports I've read elsewhere indicate they are pretty good, but maybe not everything claimed. In some houses they might be a great option even so. I've used MOCA units over coax and those are great giving you ethernet speeds of 1 to 2.5 gbps depending upon which brand you choose. They are a bit more costly, but I've used them over old in wall coax from abandoned cable TV or satellite TV installations.
