AUDACC
I have been successfully playing PCM music files from a USB thumb drive or the SSD on my Windows i5 laptop through Fubar2000 to the USB interface of the D50iii. The sample rates of PCM files show correctly on the Foobar2000 display and match the D50 display.
The ASIO+DSD output and SACD input components are installed in Foobar2000.
A DSD128 file plays successfully when Foobar2000 “Output (per device)” set to “PCM” 44.4khz or 88.2khz and the output device is “ASIO+DSD : Topping USB Audio Device”. The sample rate of DSD128 (5.6448Mhz) file showed correctly on the Foobar2000 display and the 44.1khz or 88.2khz showed correctly on the D50.
According to the D50iii manual DSD files up to DSD512 are supported. However, when attempting to play a DSD128 file with the Foobar2000 “Output (per device)” set to “DSD” and the output device is “ASIO+DSD : Topping USB Audio Device”, a Foobar2000 error message is displayed that says the D50 doesn’t accept the 352.8khz data from Foobar2000.
Is the failure to successfully play bit perfect DSD files a settings issue or does the laptop lack the compute power to decode, process and transmit the DSD correctly to the USB port?
