Alright,
@Jungstar , with the straw man out of the way, your suggestions are worth attention.
The Rooms are also a "mess" - and in my opinion, we should measure a lot more here and understand what can be done in room EQ and what are time domain issues.
Fair point. But we discuss it a lot here. Really a lot. It doesn't show up much on the reviews front page because it's not a product you can put on the bench and measure. But there's lots of case studies, some tutorials and this omnibus thread for people to discuss their measurements.
Would it be useful to have a forum thread where we can gather people's in-room frequency response measurements and discuss them? Those who did something to improve their sound based on measurements might also describe what they did and show the results. I think this could be quite interesting. What do you think?
I wonder how we could organize it better. No ideas off the top of my head.
One thing we don't see often is bench measurements of EQ. Idk if this is something
@amirm is interested in. I suppose his AP can do it. One thing I care about is how a digital product handles gain in a filter's band. For example, my WiiM mini distorts if I move the graphic EQ sliders up (in the phone app), presumably because input signals are mastered relative to zero dBFS and the WiiM doesn't compensate for filter band gain with negative pre gain. So I wonder why the WiiM's graphic EQ sliders go up above zero at all. Bench testing with discussion could be useful.
Another is tone controls. Parametric and graphic EQ are great but they are hard to use. Sometimes you just want good old bass and treble knobs. I want bass and treble knobs. Nice and easy and satisfying. This is something the audiophiles told us were bad for us and they went away. Such rot. Loudness knob is great too. Go Yamaha A-S801! This goes to your next point.
Almost nobody at 40, has a "flat hearing". But what if you could use DSP to fix it - that is basically what a hearing aid are doing.
Tone controls and more easily controlled EQ!
Actually I started a thread a while back about measuring your own tinnitus.
I searched (casually) and it seems audiologists are
Measuring Tinnitus (American Tinnitus Assoc.) as I would imagine:
- Tinnitus sound matching: The presentation of common tinnitus sounds back to patients, to help them identify their specific perception of tinnitus. The health professional may adjust the pitch and layer multiple sounds to create an exact audio recreation of the the tinnitus. Sound matching provides an important baseline for subsequent tinnitus management therapies, which are often customized for each patient.
- Minimum masking level: The volume at...
The idea was (a) calibrate your DAC and headphone amp using a resistor and multi-meter to establish the relationship between dBFS in REW or your DAW and RMS Volts, and (b) use the sensitivity that others including Amir and solderdude have measured for yoru make and model of headphones that gives you volts to dB SPL. Now on your computer you can create test signals and run DIY hearing tests one ear at a time.
