Is anybody seriously impressed with WiiM's room correction solution RoomFit™'?
I have used RoomFit with the WiiM Ultra in several rooms alongside REW measurements and Denon AVR measurements. Umik-1 on a tripod with mobile and laptop.
Always found it to be rather close to what REW suggests. A bit more aggressive to match the desired curve than REW out of the box. But apart from the PEQ preset matching the WiiM capabilities and some obvious settings I did not tune much. As we know REW can be made to move in all directions.
For the normal user who wants an easy solution and is OK with getting a good mic, RoomFit is pretty much perfect IMO.
In my humble opinion, RoomFit does a pretty good job.
The placement of the speakers in my living room is "a nightmare" - even left and right speakers do have different conditions. On top these speakers have flaws - frequency-response as well as directivity wise.
I initially did a manual set of PEQs with REW, measuring several positions, averaging them, having REW generate a set of PEQs, tweaking them manually based on re-measurements. It took me an afternoon, even though I know REW pretty well.
In the end, I'm very happy with the result.
BUT
Using the MM-Method, I was able to generate a set of PEQs within a few minutes and this one sounds almost indistinguishable compared to the one tediously built manually. The remaining difference probably is due to a slightly different target curve.
RoomFit is very doable also for people who are not deep into audio and who are not willing to spend days introducing themselves to REW. I.e. people who just want to enjoy a good sound and listen to music.
Making room (and speaker) correction accessible to “everyone” is an achievement that I cannot praise highly enough.
Hopefully with the popularity of AI someone will create a free version of REW that is as easy as RoomFit to use
I commented on this thread a while back, but RoomFit has since been significantly improved. There is a moving mic measurement, as well as the option to change the smoothing to variable. There seem to be other improvements under the hood, because the results are pretty much identical to what I get with REW now (using a calibrated mic with both), so there is no point in using REW anymore. I haven't used Dirac Art or other rooms corrections, but I suspect they aren't any better than RoomFit based on my experience with REW vs RoomFit.
It probably helps that I'm starting with an RSL sub and Ascend Acoustics Sierra V2 speakers. :)
Another new feature is the "Auto" room curve, which in my case seems to be between B&K and Harman in bass response. I compared the two and still preferred Harman, but Auto is definitely worth trying.
REW is already free and quite easy to use. Sorry to interrupt all the WiiM praising here but PEQ is one of the most basic forms of DSP, just as moving-mic measurements are, since phase information is lost. It may be simple and quick to use, but it certainly is not great DSP or the ultimate solution.
I absolutely agree there are more sophisticated (and technically more correct) options around, no question.
Room modes and frequency response flaws of speakers are primarily minimum-phase and thus compensating them with PEQ is nothing to blame.
When it comes to reflections (not minimum-phase) it's anyway to be considered which of the effects to compensate for to really improve things.
You can get a huge improvement by simply getting the tonality right and this is a really nice low-threshold access for a broad audience.
The WiiM Streamers are highly functional and affordable, and RoomFit is a bonus feature that can significantly improve the sound quality of a basic system in a room that hasn't been acoustically treated.
No arguing with that. They identified a clear gap in the market for affordable, user-friendly gear without sacrificing features. What really impresses me is how fast they adapt to user feedback. Their room correction algorithm has evolved several times in short order, getting better each time. No wonder they’re selling like hotcakes.
The ADC (and DAC as well) of the "Mini" are not particularly suited for this setup.
Inserting the "Mini" between pre- and main amplifier (i.e. behind the volume potentiometer) means the ADC/DAC chain will run at low levels when you listen at low levels.
This may still sound enjoyable, but I would rather insert the "Mini" in the Rec-out -> Aux-in path in case the amplifier provides a separate input selection for the Rec-out.
The "Mini" then consistently runs at line levels, however this bears another risk. The ADC of the WiiM Mini has a full-scale input voltage of 1Vrms according to its specifications. This may not be safe for some line level source and result in clipping.
I plan to insert a "Pro Plus" in my A32 Arcam integrated amplifier (Rec-out -> Aux-in) in order to have RoomFit for the analog sources too. The Pro Plus has a higher quality ADC and tolerates 2Vrms input level, so this should be safe for most line level sources.
I have been using a Pro+ in the tape monitor circuit in my preamp for almost a year just for room correction. It works great!
That's good news :-)
Fortunately I still have an old-fashioned integrated amplifier that allows for a tape-monitor insert.
Yes indeed. My Levinson preamp has two tape monitor circuits. I love having the connection flexibility. Good luck with your room correction.
Levinson preamp
That's exactly the kind of gear I used to yearn for as a teenager and young adult, licking my fingers and pressing my nose flat against the store window
I'm just impressed they made the effort. Much less put it in $100-$175 devices.
I tried with the mobile Wiim app -and the Smartphone mic- and wasn't overly impressed with the result. :-)
Reactions: OCA
This is the final result of a RoomFit with a pair of old Genelec 1030A standing on the floor, one of them even in the corner. I decided to leave the peak at ca. 50Hz untouched.
The sound is perfectly enjoyable.
These are the corrections needed.
I'm using a UMIK-1 with calibration file and the Moving-Microphone Method.
A very nice thing is that you can apply some graphic or parametric EQ on top of RoomFit.
I'm using RoomFit to get the frequency response about right and I can still do some adjustment to my taste without interfering with the RoomFit PEQs.
I am seriously impressed with the ridiculous feature set of my WiiM Ultra. The fact that this device at its price point includes room correction is staggering.
Yes, that's the thing. You get the improved RoomFit, a very nice streamer that supports a good number of subscription services and local network protocols, a very decent DAC, a huge variety of settings, the ability to stick to a bit-perfect signal chain if that's important to you, a seemingly constant stream of upgrades to all aspects of the software, and a price tag under $400US. The value proposition depends on how many of those features and aspects you want to use of course, but it's not hard to see why they're so popular.
I agree - but the self contained version on a smartphone may be something I'd caveat with the many possible improvements that can be derived with a better platform, at least when it comes to the Wiim Mini via a Samsung S26 Ultra.
I agree with you on that. The situation is much better with iPhones because there are fewer mic variations and Wiim has access to Apple's calibration data for each mic.
And my understanding is that Roomfit will work with a Umik-1 or other calibration mic - but of course you have to connect the mic to your phone. I would like for the next iteration of Wiim hardware and software to allow for direct connection of the calibration mic to the Wiim device, and loading of the mic's calibration data onto the Wiim device, just like you can do with a MiniDSP. That, combined with the many improvements to RoomFit over the past couple of years, would make Roomfit a truly viable room correction tool.
I can confirm that it works with the Umik.
But what advantage would there be in connecting the mic to the WiiM rather than the phone, given that the calibration file works on the phone?
