No. The UMIK-1 must be connected to the device that is running the WiiM Home App.is it possible to plug-in a UMIK-1 mic in the same USB port so that it works with RoomFit?
You can send the sweep to any of the WiiM's inputs:In the case where the UMIK-1 is used with a laptop, how does one send the sweeps to the Wiim Ultra?- is via 3.5mm out on the laptop to RCA input on the Wim Ultra?
Oh ok, so I have to use a USB C to USB A converter?Just plug the umik via usb-c in your smartphone, running the app.
- Analog RCA Line in
- Bluetooth
- Chromecast/UPnP/DLNA
- SPDIF
But if you use RoomFit, then there is no need to manually input a sweep signal into the WiiM Ultra. WiiM Home will handle that all internally.
A manual sweep is only required if you want to use software other than WiiM RoomFit for correction. E.g. Room EQ Wizard.
You can use a standard USB-C to USB-C cable. No converter required.Oh ok, so I have to use a USB C to USB A converter?
I don't think my UMIK-1 has a USB-C port but it came with a long adapter cable with a USB-A connector on one of the sides.You can use a standard USB-C to USB-C cable. No converter required.
Mine has USB-C.I don't think my UMIK-1 has a USB-C port but it came with a long adapter cable with a USB-A connector on one of the sides.
I have a small 4-inch USB-A to USB-C adapter.
Yes, it's because it's a later version.Mine has USB-C.
Probably the easiest route. Somebody probably sells C to Mini-B cables if you really want one.Oh ok, so I have to use a USB C to USB A converter?
It did last time I checked. I doubt they'd remove that option.Does the Wiim Home app accept the calibration file for the mic?
I does, I used Umik 1 with Wiim Amp Ultra during the weekendProbably the easiest route. Somebody probably sells C to Mini-B cables if you really want one.
There are USB-B to USB-C cables, too.I don't think my UMIK-1 has a USB-C port but it came with a long adapter cable with a USB-A connector on one of the sides.
I guess I can look for one. Do you think attaching a short USB-A to USB-C cable at the end of a long USB-B to USB-A cable might bring issues in terms of powering up the Umik-1 mic?There are USB-B to USB-C cables, too.
No I do not.Do you think attaching a short USB-A to USB-C cable at the end of a long USB-B to USB-A cable might bring issues in terms of powering up the Umik-1 mic?
Thank you for your answer.means the ADC/DAC chain will run at low levels when you listen at low levels.
