olds1959special
I may order a cheap passive volume control that I'm going to try in between my dac and power amps. Will it sound better than my tube pre amp?
I would say in your case with an AI tube preamp, probably not. A lot of distortion from a preamp like that, which will most likely "sound better".I may order a cheap passive volume control that I'm going to try in between my dac and power amps. Will it sound better than my tube pre amp?
I have several tube preamps, and none of them are noisy. Make sure the cable routing and where you place your tube pre is not the cause of the noise. 90% of the time NIOSE is poor cable routing, and one of the best reasons to use compliant XLT cabling and equipment if you can.I can try a cheap volume knob and see, but I assume the tubes are fine for now, even with the slight hum/noise and the distortion.
audiosciencereview.com
The issue(s) for passive attenuation will be (can be) insertion loss and/or variable impedance as a function of level of attenuation. A constant impedance attenuator. Cheap probably isn't a value-add for a passive attenuator.I may order a cheap passive volume control that I'm going to try in between my dac and power amps. Will it sound better than my tube pre amp?
I'm going to try a passive volume control with Alps RK16Passive attenuator with a 10 kOhm potentiometer would be fine for the Kenwood Trio L-05M with 50 kOhm input resistance. For this the low pass limit frequency would be around 30 kHz (- 3 dB) when a RCA cable with 10 meter length would be used. So for 1 m the limit is 10x which is enough not to dim the highs.
I ordered a Solupeak volume control based on Alps RK16. Will this work?Passive attenuator with a 10 kOhm potentiometer would be fine for the Kenwood Trio L-05M with 50 kOhm input resistance. For this the low pass limit frequency would be around 30 kHz (- 3 dB) when a RCA cable with 10 meter length would be used. So for 1 m the limit is 10x which is enough not to dim the highs.
Except for maybe a bit of HF rolloff if driving a capacitive load, a passive preamp, which is just a volume control pot or stepped resistive attenuator and input switching facilities, cannot introduce any distortion. It takes an active device to do that. You could get a bit of hiss, likely inaudible, from the intrinsic noise that resistors generate. Best practice is to use as low a resistance as is practical in the circuit to minimize that small amount of noise.Depending on the design quality, it should have less distortion than your tube preamp.
