Justin8888
- Joined
- Feb 18, 2026
- Messages
- 13
- Likes
- 2
Im trying to wrap my head around the need (or maybe lack of need) for a bunch of power for a nearfield/desktop setup. Im looking into running two Schiit gjallarhorns f in mono and have not settled on a speaker. The price on these amps is attractive, they are compact, American made, well priced, seemingly well built with a strong reputation behind them. And placing them near each speaker is ideal for my layout. Redundancy is nice as well if one goes down.
But this concept of needing headroom or, as I noted below, "a beefy amplifier" is confusing to me.
https://www.audiosciencereview.com/...-debut-reference-dbr-62-speaker-review.12232/
In this case with the dbr62, theres a sharp drop to 5ohms. These are 86dB speakers. Assuming I am listening at the max volume I would ever consider, lets say average 90dB (rare, but sometimes I get there). Im using less than 2 watt of power which means if these suddenly require a spike in power due to an impedance drop, they can spike to around 10x the continuous and before they hit the ~2A cutoff on the ghorn.
Anyway, this is one example. I have not yet settled on speakers, but I would like to know how I should be thinking about how much power I need to accommodate large, and particularly, low swings in impedance to maintain consistent performance in nearfield. Regardless of speaker, if the continuous wattage is low, like 2W, how much headroom to a really need, even for "hard to drive" speakers ie speakers that drop even lower to like 2ohm (looking at Q1 meta and ML 15i, and some others). Do I really need 125-200w per channel for this application? What constitutes a "beefy amplifier" other than power output?
However, note the area I have circled. Impedance is high at about 8 ohms but the phase angle is quite acute at nearly 50 degrees. This means the speaker will ask for current when the output voltage is very low. So you better have a beefy amplifier to drive this speaker.
