Is a $5,500 professional Trinnov calibration objectively better than a knowledgeable DIY calibration?
Getting a room from nearly there to truly optimal can be tougher than rocket science.
yes, we tend underestimate others people tasks and skills.
Every slighlty overweight dad would definitely score that easy shot, that Messi missed. And they would get the tactics right, unlike that incompetent Guardiola ;-). [I have my season ticket next to a group of guys like that, they spend 90 minutes explaining how they woudl do it differently to players and how the coach got everything wrong in his team selection]
The “answer” also depends on what yours objectives are. If you have unlimited funds and just want a great HT room, why not use a top calibration service. But at the other extreme. If this is your hobby and you get pleasure from doing things yourself and understanding what’s happening then you may not want to use a calibrator. Obviously these are the bookend extremes. Lots of room in between.
My plan is to train myself on my current setup with the help of AI [I am still thinking of getting my own Earthworks M23, instead of UMIK]. now I am vibecoding som script for REW files analysis.
Then I will calibrate my new theatre best I can, with all the acquired experience.
And then I will hire pro calibrator to see, whether there is something still to be gained. If calibrator achieves nothing more than me - good. if he still improves something - even better.
Definitely, need a new mic if you want accurate phase and low frequency THD. I didn't know you were using that one in your WaveForming measurements you were kind enough to post, but I bet your system measures even better with a decent mic :)
Phantom power was always too big of a hassle for me, and UMIK is not THAT bad, useless in treble, but ease of use compensates for.
Just couple of minutes ago I could borrow this MM1 and Focusrite from a friend.
I am looking to see differences to UMIK, I will now focus on Optimizer REW pre-work - this is <200Hz corrections to be run before Optimizer. I have now different L-C-R setting for bass [woofers are active and DSP controlled on my hybrid MartinLogans], will try different REW measurement routine, Just this pre-work workbook has 28 slides ;- )
I'd only use it for amplitude. If you're trying to time align drivers by hand, you need a professional setup. Phase accuracy is very important. The cheapest pro option might be an RME interface that has a mic pre amp with phantom power and has AES in/out. RME ASIO drivers are rock solid and work great with REW. You don't need a $10-20k setup though.
I am using REW measurements before running Optimizer - in the end I will create couple of filters to remove EQ'able peaks below 200Hz and give Optimizer cleaner run. In my case it helps a lot - it places before curve differently so total Optimizer filters decrease by about 50% and I do not need to employ any filters above 2khz.
Sir, wanted to thank you for bringing this topic - it was inspiration for me to start the project "how to be a pro calibrator for my own theatre" I will run new Trinnov calibration including dreaded WF measurements [it takes half day in my case ;-)]
I want to try this
instead of this Trinnov recommendation.
AI's advice is actually somewhere in between
