Found a way to avoid the CCK or Lightning USB dongle.
Get a Fiio LT-LT3 lightning to USB C lead and it just works.
It also works with lightning extension cables, so plug extension into iDevice and plug the Fiio lead into that and then connect to your DAC etc. The extension leads are handed so it doesn’t work flip the Fiio lead around.
If your USB input is USB B (square plug) on your DAC or combo unit get a USB C to B adaptor and the Fiio lead still works
If you need to charge your iDevice at the same time use wireless charging.
Find this set up less bulky and cheaper.
Amazon UK items for ease attached but get the Fiio lead from other online sellers or AliExpress as they are cheaper.
