Old habits die hard I guess.
I do have a dedicated but these days we're finishing the top floor which is basically a living room.
Fairly minimal as you can imagine by my comments all this time, imagine a big T shape room which creates essentially two boxes at the front ending up to what I can describe as a crystal wall (which can be opened, completely, high view is nice) .
So no where to place speakers as "rules" dictate other than in the middle of this opening (imagine the upper section of the T) which is out of the question of course.
Still...
You can guess that the dedicated 20A lines are in place at the side of one "box" and most likely it well end up in a thing having a wall on one side and a crystal on the other
I guess something minimal will work there , at the 5 x 6 meters that create this virtual box I don't dream of 200 lit. mains monitors. Also treatment is out of the question, curtains as well.
Will that stop me setting up something half-decent so the place can be alive and show that actual people living in? Nope!
So, it does make sense to get a decent speaker and correct as much as I can down low with DSP. Speaker must be able to help with this though.
And if it has the meat at mid-bass that I value, even at lower SPL even better!
If we are talking mid and high frequencies, and their reflections, then curtains are one option, but there are also various sound absorbent treatments that can be used, or sound absorbent panels (which can look like artworks) - bookshelves full of books can work very well too... but yeah, the barebones "modern scandinavian" look (as shown in most B&O brochures...) is a mess for reflections!!
If the space is large enough, and that means the reflections are sufficiently delayed, then it will merely end up being an ample soundstage... our ears and brain automatically filter out reflections of the primary direct sound if it is sufficiently delayed - so as long as the main speakers are far enough from the side walls, it may not be an issue!
Bass frequencies are not susceptible to furnishings and standard absorbers/diffusers, they need bass traps which are LARGE...
Having said that, the construction material used in the space will have a major impact - if it is "solid" such as brick or concrete - then it will reflect bass - the room will pressurise (making the bass sound substantially louder) and the room will have long decay/reverb - if the room boundaries are "lightweight" (drywall on studs) - then they are effectively transparent, and the bass will pass through to either the outside of the building or to the boundary where it meets something solid.
The bass is very amenable to treatment via DSP with Dirac ART - where the electro-acoustic wizardry is used to control/eliminate the reverb/decay.
The key thing you need to avoid, is a speaker right next to a reflecting surface - think of sound as a light, and surfaces as mirrors... a surface that breaks up the audio, disperses it in different directions, is like a matt painted wall - a light you shine on it, sort of illuminates the entire room, but you don't get the beam from your torch reflecting directly back or around the room as you do in a mirror. (Books on bookshelves both absorb certain frequencies, but the varied shapes of the spines also disperse it, breaking up the soundwave... very handy!)
Keep the speakers 2m away from a reflective sidewall if possible ( you can get much closer if the wall has dispersing "treatments")
Another consideration is how the speaker disperses sound - narrow/controlled dispersion speakers will minimise the sound outside of their narrow cone ... wide dispersion or omni speakers will spread sound in very direction... controlled dispersion speakers are more easily placed...
A good room will provide quite a bit of reflected sound which will fill out the soundstage, but the reflections are sufficiently delayed so as not to smear the imaging effect. - if the room is large enough, you can even use omni's (or bipole / dipoles) and place them well out away from walls - the resulting effect when listening to stereo is fabulous, and typically there is much less of a "sweet spot" effect.... Controlled dispersion speakers are the opposite and at the extreme, can result in the "head in a vice" effect, with only a very small sweet spot.
At 5 x 6 meters, you could place speakers on the 5m side 1m away from each wall, 3m appart - a little furnishing on the side walls might break up reflections close to the speakers - if one of the 6m side walls is all glass (and curtains not an option), you probably should aim for controlled dispersion speakers - and place them toed inwards towards the listening position.
Make sure you purchase a Receiver/Integrated that supports Dirac ART - as that can be used to control the bass reverb/decay.
Good luck!
