Within a just released December SOS magazine review Phil Ward (speaker designer and studio gear reviewer) appears to be closely on the same page as I on this area of speaker design:
"Any conventional two‑way speaker, in which the full audio band is covered by a bass/mid driver and a tweeter, potentially incorporates a challenge: engineering a bass/mid driver that extends high enough in frequency to integrate with a tweeter that extends low enough is inherently difficult. If the bass/mid driver has a diaphragm large enough to reproduce low frequencies at a reasonable volume level, it will become significantly directional at the top end of its band; and at said top end of the band, a large diaphragm will have stopped moving as a whole and be working in a somewhat chaotic, resonant mode. The tweeter issue is that if the diaphragm is small and light enough to reach up to 20kHz with acceptably wide dispersion, it might struggle to reach low enough in frequency to integrate with the already bandwidth‑challenged bass/mid driver whilst retaining acceptable power handling and distortion levels. Furthermore, even when a bass/mid driver and tweeter are successfully integrated, there is likely to be a significant dispersion mismatch between them. The dispersion of the tweeter at the bottom of its band will be inherently wider than the dispersion of the bass/mid driver at the top of its band. The result of that will be potentially audible non‑linearity in the off‑axis response."
Phil Ward Dec 2025 Sound on Sound magazine, Amphion One 18X review:
https://www.soundonsound.com/reviews/amphion-one18x
