Hello ASR members,
We're excited to officially introduce the
SMSL R100, our new
R2R high-resolution audio DAC designed to redefine the classic analog sound for modern audiophiles and desktop audio enthusiasts.
R100 Design Philosophy: A Tribute to the Classic R-2R Architecture
The R-2R DAC architecture once represented the pinnacle of digital audio conversion technology. With its natural, realistic, and highly musical sound signature, it became the heart of many legendary high-end audio products. However, true classics should not simply remain in the past.
The SMSL R100 is not a simple reproduction of traditional designs. Instead, it re-examines and unlocks the full potential of classic R-2R technology through modern audio engineering. By combining advanced digital processing, ultra-precise clock management, optimized analog output design, and sophisticated power supply solutions, the R100 allows these legendary DAC chips to achieve a level of performance that exceeds their original era.
We believe that true technological heritage is not about repeating the past, but about understanding its essence and giving it new life with the most advanced technologies available today. This is not only a tribute to a classic technology — it is a new exploration of the ultimate potential of R-2R digital audio.
Every element of the R100 has been carefully considered: this DAC pairs two premium ADI AD1861-J chips in a classic R2R architecture with built-in De-glitch circuit. This advanced design minimizes switching errors, delivering a pure, natural, and deeply musical analog sound.
To ensure uncompromising performance, every unit is individually calibrated via a precision MSB adjustment circuit, utilizing carefully screened J-Grade chips for perfect channel matching. It supports a proprietary USB receiver (up to 768kHz/32-bit), a proprietary DSD conversion algorithm for native high-res playback, and a proprietary SPDIF algorithm to significantly reduce Jitter.
Versatility is at its core, featuring web-based PEQ customization, three switchable sound modes (Direct, EQ1, EQ2), and a custom FIR digital filtering algorithm with 16x oversampling. Building upon the legacy of the flagship VMV D3 platform, its analog filter circuitry ensures transient response and musical detail. Encased in a precision CNC-milled chassis with two oversized transparent viewing windows, this DAC flawlessly merges high-end engineering with elegant modern aesthetics.
High-Performance U.S. ADI R2R Professional DAC Chips
The R100 features two high-performance ADI R2R professional DAC chips, AD1861-J, staying true to the core essence of analog audio.The device is equipped with a proprietary, factory-built “De-glitch” circuit that optimizes the signal processing workflow at the core of the analog-to-digital conversion, effectively avoiding and reducing transient errors and signal distortion during conversion, while filtering out excess digital noise and harsh artifacts. This ensures that every audio signal conversion is precise, stable, and pristine, delivering a warm, transparent, and authentic analog listening experience—characterized by a natural, relaxed timbre and a nuanced reproduction of the music's true texture—far removed from the coldness often associated with digital audio.
Customized Personal Listening Acoustics
Featuring a convenient web-based PEQ customizable equalizer, the R100 requires no software installation or professional technical knowledge. Simply enter the settings interface through a web browser to fine-tune the sound to your preference.The device provides Direct EQ, EQ1, and EQ2 three independent sound effect storage modes, supporting customized parameter saving. Once your preferred sound settings are tuned, they can be saved with one click, eliminating the need for repeated adjustments.
Precision Calibration & Comprehensive Engineered Layout
To ensure uncompromising performance, every unit is individually calibrated via a precision MSB adjustment circuit, utilizing carefully screened J-Grade chips for perfect channel matching. The device supports a proprietary USB receiver (up to 768kHz/32-bit), a proprietary DSD conversion algorithm for native high-res playback, and a proprietary SPDIF algorithm to significantly reduce Jitter.
Furthermore, the entire chassis is crafted using high-precision integrated CNC milling, formed through multiple fine grinding and polishing processes. With clean and minimalist body lines, it combines minimalist aesthetics with hardcore craftsmanship. It is not only a professional audio decoding device but also a highly textured desktop craftsmanship ornament.
Self-Developed High-Precision Reception Algorithm
Addressing the pain points of digital audio transmission, the dedicated self-developed high-precision SPDIF receiving algorithm deeply optimizes the digital signal transmission logic, effectively suppressing and reducing the JITTER clock jitter generated during signal transmission. It eliminates issues such as dry sound, blurred soundstage, dynamic compression, and loss of detail caused by clock jitter, making digital signal transmission more accurate and stable. While strengthening the foundation of the sound, it effectively expands the musical soundstage, enhancing the separation and three-dimensionality of the sound, resulting in an overall listening experience that is transparent, solid, and clean.
Perfect Fusion of Classic R2R and Modern High-Res
Breaking through the limitations of traditional R2R architecture sources, it incorporates a self-developed DSD high-resolution conversion algorithm, allowing the classic R2R decoding architecture to seamlessly accommodate DSD high-resolution audio input. Through high-precision algorithmic conversion, the massive volume of DSD high-resolution audio data is precisely transformed into the analog signals where the R2R architecture excels. This not only preserves the traditional R2R sound characteristics—a thick, warm, and relaxed analog timbre—but also combines it with the delicate analysis and rich details of DSD high-resolution sources, achieving a perfect fusion of retro analog charm and modern high-resolution audio quality, resulting in a sophisticated and enduring listening experience.
Balanced Crosstalk
Inputs and Outputs
Specification:
| Specification | Details |
| Input | USB / Optical / Coaxial |
| Output | XLR / RCA |
| Output Level | XLR: 3.5Vrms
RCA: 1.75Vrms |
| THD+N | 0.003% (-90dB) |
| Dynamic Range | XLR: 107dB
RCA: 108dB |
| SNR | XLR: 107dB
RCA: 108dB |
| Output Impedance | 33Ω |
| USB Transfer Mode | Windows 7 / 8 / 8.1 / 10 / 11 (Driver required)
Mac OSX 10.6 or Later, Linux (Driver not required) |
| Bit Depth | USB: 1bit, 16-32bit
Optical / Coaxial: 1bit, 16-24bit |
| Sampling Rate (USB) | PCM: 44.1 ~ 768kHz
DSD: 2.8224 ~ 22.5792MHz
DoP: 2.8224 ~ 11.2896MHz |
| Sampling Rate (Optical / Coaxial) | PCM: 44.1 ~ 192kHz
DSD: DSD64 (DoP) |
| Power Consumption | 2.6W |
| Standby Power | < 1W |
| Dimensions (WxHxD) | 170 x 39.8 x 136mm |
SMSL R100 – Precision Redefined for Desktop Listening.
The SMSL R100 is now available. For more details, please visit our official website: [
https://www.smsl-audio.com/portal/product/detail/id/957.html]
We look forward to hearing your thoughts on ASR!
