Introducing the Phono Cartridge Measurement Library
One last note.
Please note that in almost all MM cartridge models the bracket is mounted to a plastic element, a material that vinyl enthusiasts dislike so much. ;)
AT-OC9XML w/ LH11H
Notes
  • New cart <3hour usage
  • Reloop 7000MK2 turntable
  • Mounted on AT-LH11H headshell
  • 2g tracking force
  • 2x e1da apu as phono, unbalanced 23.5k load 100pf
  • cables 182pf + 150pf turntable (from rcas to headshell terminals)
  • CBS STR100 issue3 test record NM condition
After some troubleshooting it seems one my apus has +20db~ noise with the stylus in the air, the slight channel mismatch is due to this as well. I'll update the measurement when I get the issue fixed.
I have this cart and I’m using a Parks Audio Waxwing as my phono stage. I haven’t read deeply into this thread, so forgive the maybe obvious question: Can I use these measurements to reliably adjust the frequency response of my cartridge using the adjustments available to me with the Waxwing app, or are the unknown variables between our setups going to make that futile?
That said, i think I have everything I need to take my own measurements of this cart: I have the aforementioned Waxwing digitizing the signal and running to my MiniDSP SHD (which I can interface with my Mac) and I’m practiced at using REW. I also have a Ortofon test record with sweeps. I’m keen to go to the trouble to do this—a combination of Audiophile Nervosa (a real and serious condition) and because it could be a fun and rewarding opportunity to learn something. What is the community’s advice?
Use this measurement:
It is plus-minus 1dB using a 100ohm load. Feel free to adjust with that if you can use the same load. Not sure if it is really needed unless for archival purposes.
Unfortunately Ortofon test record has flawed frequency response sweeps so it is not recommended for that purpose. At the very least you want to use a CBS STR-100.
SHURE V15-RS
this is a made for radio shack shure v15. it was sold as unused in box. the brush looked unused and the hardware was still in the sealed bag. the body shares the same electrical specs as a v15vxmr and vstiii. the stylus is beryllium with a hyperelliptical stylus. the diamond looks a little different than other shure hyperellipticals ive had. they usually are have a narrower round shank ime.
heres a hyperelliptical from a v15v with a hardened suspension
they frequency response on this looks just like the v15vxmr i posted. no surprise there given the specs.
this needle, unfortunately, is trash, but it's interesting to see the measurement of such a needle.
I can confirm that my original VxMR stylus look similar in fr response. This is one reason the JICO SAS/B suits these bodies well; the added resonance 10-20 kHz helps. Not so with the V-MR bodies; peaking goes into the 4-5 dB range.
ORTOFON CONCORDE MUSIC BRONZE
  • 1.8g tracking force
  • My record has a warp and refuses to be clean. Side 2 used first sweeps.
  • One of the new "music" models in the DJ integrated headshell style, suitable for Technics tonearm geometry, which mine is
  • Info can be found here. Fineline stylus.
  • Typical? Ortofon lift at HF, two cap loadings shown. Increasing doesn't wholly help, may need resistive changes.
  • fantastic channel balance!
  • This is the azimuth with best HF symmetry, but xtalk then not good.
  • Never seen as bad midrange "tonearm" resonances on my setup! Perhaps due to the "headshell"?
  • Fluff on the cantilever that could not be removed. See below.
ORTOFON CONCORDMUSIC BRONZE
  • View attachment 403270
So many questions! That mid-range resonance is indeed troubling. I don't recall seeing anything like that here and it is worth investigating. You may even want to see if you can get a replacement to confirm it. The idea that it could have a problem would drive me crazy and it's a legitimate reason to try out a different copy or even return it.
Aero's measurement at #1364 (with tilt issues) of the older concord 20 showed a hint of the resonance issues too, but I will try and at least confirm limited to the cartridge.
The OM also have resonances in this region but not this high. To get flat HF the Ortofons usually need a bit lower R, 36-42 kOhm
I would start by cleaning that needle tip. We put on good glasses. :)
We unscrew the insert, take out the needles, take a toothpick on which we roll some cotton wool and remove this dirt.
We do not make any nervous movements ;)
The needle tip should be clean. :)
The cartridge has a wrongly set azimuth. In a Technics turntable there is usually a lot of play in the headshell attachment to the arm, which allows for azimuth correction. Setting the correct azimuth is a pain :) You have to enter minimal changes and take measurements
Drama :)
If after cleaning the needle the measurement has such a jagged frequency response, I would return this needle to the seller.
By the way.
The bracket attachment in this model is the simplest possible, such a budget design. The bracket is pressed into a hole made in the suspension, which is made of a piece of "rubber" It probably couldn't be easier :)
Sometimes it helps to gently! move the bracket left, right, up and down
Ortofon MC Jubilee
New.
After 5 attempts to set a better azimuth, I gave up.
The Technics 1200GR2 turntable has terrible headshell mounts and the company's headshell is poor. Adjusting the azimuth is a nightmare ;)
A good turntable cartridge, unfortunately quite expensive.
Anniversary model, no longer produced.
If you set filenorm to 0, the two channel frequency responses will be normalized to each other at 1kHz, indicated by the X there. So you can't get a sense of the channel balance. If you going into the script and set to 1, you then see the true channel balance between L&R.
Thank you
I didn't know that this parameter in the script should have the value 1.
I noticed that in the measured copy, in the range of about 2 kHz-5 kHz in one of the channels (red line) there is some problem with the crosstalk parameter. A different setting of the phono cartridge and a different anti-skating value does not change the value of the measurement, the red line still has large fluctuations of the crosstalk parameter. Do I understand this correctly?
Thank you
You can just rerun it and update your post(s).
Resonances in the cartridge/arm.
There is no such problem in the previously performed measurement of the Ortofon MC 5000.
In my opinion, the problem concerns only the phono cartridge.
I took a closer look at the cantilever in this specimen, using a magnifying glass, I can see that the cantilever is not glued perfectly straight. The connection of the boron cantilever with the aluminum element of the cantilever is made with additional transparent glue.
It looks as if this element was simply repaired, and it was not the original factory connection.
I have a second copy of this model, it was purchased directly from Ortofon. I checked under high magnification, the connection of the boron cantilever with the metal element is made without the use of transparent glue, the cantilever is glued perfectly straight.
I will measure this specimen in some time.
I filed a complaint with the seller.
