- Joined
- Mar 30, 2019
- Messages
- 1,311
- Likes
- 2,396
- Thread Starter
- #1,321
Back to the questions I asked previously, thank you to the suggestions of particular cartridges. Looking at what you’ve recommended was helpful. On the question of MC cartridges — I see some interesting ones here, but I’m wondering if it’s worth going down that road. Is there really an advantage? I’m not sure I see it in measurements, but maybe I’m missing something?
This is a difficult question as there are so many different variables that you can privilege that changes the situation. Are you looking for flat FR? Is there something to taking advantage of a (well-controlled) high frequency resonance in order to mitigate a bit of the FR sloping that occurs as the cartridge moves toward the outer groove? (MC cartridges tend to slope upward more generally speaking.) Then of course there is cost (MCs tend to be more expensive) and whatever your definition of value is. Then there is the set-up you have and the question of whether the cartridge is compatible. (See the last few measurements.)
Assuming "going down that road" means having to buy a MC phono stage in addition to the cartridge the way I personally think about it is that there is nothing the best MC cartridge in the world can do that a MM can't do so the question is whether the extra expense is worth it. (Though of course making sure your MM cartridge is performing optimally may require a phono stage with more loading options.) It could simply be a question of comparing the final costs of the options you are interested in, and this is assuming "value" really matters to you. Remember too that you can also invest in EQ in order to try different FR responses. You don't even need "the best" MM cartridge either.
Other things that to me are much more important are the stylus and cantilever. I think having a nice micro-linear diamond based cartridge that tracks well is much more important than whether it is MM or MC.
Funny enough the early version of the script as we now know it emerged in the MM vs MC thread. So this thread is very much related to your question. (And I think you kind of have your answer already because of it.) You may find it interesting.
https://www.audiosciencereview.com/forum/index.php?threads/mm-vs-mi-vs-mc.18636/
